need help asap!read! need help asap!read! - diyAudio
Old 30th June 2006, 01:02 AM   #1
slamin97s10 is offline slamin97s10  United States
Default need help asap!read!
i have a question im running 3 kicker comp vr 12s dual 4 ohm to a kenwood 1000 watt i dont remeber the model number but im running it in series at 2.7 ohms and the amp is shutting off it says it can be ran to 2 ohms or 4 is 2.7 to much for it everything is brand new the amp has a cooling fan any suggestions?
Old 1st July 2006, 09:24 AM   #2
30bandgeek is offline 30bandgeek  Fujairah
nominal impeadiance is nothing man just remember that.
Your subwoofer system probally drops below 2 ohm's at a specific frequncie.
change the q of you box to have a impeadance curve above 2 ohms throughout the bandwith desired. or just turn your gains down!! i mean it. Siginal saturation will cause clipping and make things real hot real fast. Just be smart about it. If you want more low bass dont turn up the low bass turn down the high bass and than turn up volume master more to compensate for siginal loss.
Andy
What you have a Metcal...So do I..
need help asap!read!Hide this!Advertise here!
soundstream help ASAP audiobahnkid592 Car Audio 3 12th March 2009 09:59 PM
Need Help Asap msj965 Parts 2 12th February 2009 02:44 AM
XO help ASAP VictorG Multi-Way 2 12th August 2003 03:45 AM
Copyright ©1999-2017 diyAudio
