Go Back   Home > Forums > General Interest > Car Audio
Old 29th June 2006, 08:42 PM   #1
tjmehta is offline tjmehta  United States
Angry Blown amp (reversed polarity)
Hey guys,
I have a 'boss audio rip 896' that i hooked up wrong; I hooked up the power to the gnd and the gnd to the power. I saw a long zap...I hooked it up correctly and the protection light keeps coming on.
I opened up the amp and tested the MOSFETs BJTs and all other transistors on the sides. All of them are okay..none are melted at all ..and all test correctly with the diode check on my digital meter.
I next tested the reverse polarity protect diodes..those were fine.
I tested the input filtering caps and those seem to be fine also.
I am totally lost now on what to check. I want to believe its the temp sensor (thermister / thermoresistor)..or maybe even the logic chip (or op-amp or w.e that chip is, 's494p').
What fully confuses me is why the reverse polarity path didnt protect the rest of the circuit. The path goes through the diodes and directly to the fuses... but neither blew.
PLEASE HELP!
tj
tj
Old 29th June 2006, 08:50 PM   #2
poobah is offline poobah  United States
poobah's Avatar
got a schem?
Old 29th June 2006, 09:20 PM   #3
anatech is offline anatech  Canada
anatech's Avatar
Hi tjmehta,
If everything but the power was hooked up and you hooked up positive first, you burned the ground traces or resistor between the signal ground and power ground. It is possible to cook a heat unit that way, or crossover (or all of it really).
Check with an ohmmeter first. I'm hoping it was just the resistor that is commonly used.
-Chris
Old 30th June 2006, 01:02 AM   #4
I just took a look at that. it doesnt look like there is a resistor there..there is actually a capacitor there.
am i looking at the right thing (attached pictures)
any other guesses?
thanks
tj
Old 30th June 2006, 01:02 AM   #5
another pic
tj
Old 30th June 2006, 01:11 AM   #6
anatech's Avatar
Hi tjmehta,
Have a look near the input of the amp, or between the power and amp sections. You need a DC path and that will not be a capacitor. Some resistors can burn out and look perfectly fine from the top.
-Chris
Old 30th June 2006, 01:27 AM   #7
i tried to attach pics to my previous posts...but i dont think it worked
so i posted them on my website ::
http://www.prism.gatech.edu/~gtg158w/gndpic.jpg
http://www.prism.gatech.edu/~gtg158w/gndpic1.jpg
(not the cap being tested)
If u can see the numbers...it says C51..C=cap
is that the right point im looking at though..or where should i look?
thanks
tj
Old 30th June 2006, 01:28 AM   #8
im looking around the inputs for a burnt resistor...
i tested the resistance btw the pwr ground and the rca inputs' ground and both came up with a resistance. so nothing should be burnt out.
tj
Old 30th June 2006, 01:31 AM   #9
anatech's Avatar
Hi tjmehta,
What value did you come up with?
A blown resistor would have been the best outcome.
Have a good look at the bottom of the board. Take your time and use your glasses, or if you aren't like me, a magnifying glass.
-Chris
Old 30th June 2006, 06:56 AM   #10
it has two L/R pairs (4 channel amp)
each of the RCA-GNDs individually to the PWR-GND => ~4.67ohms
tj
Can a toroid be reversed? leadbelly Power Supplies 5 2nd September 2007 06:34 AM
Help! I just fried a mini-Aleph (Polarity reversed) Russell Sit Pass Labs 0 10th December 2006 08:10 AM
reversed signal polarity? G_a_r_e_t_h Car Audio 19 14th September 2006 04:01 AM
Reversed polarity on Sprague Powerlytic starbase218 Solid State 11 23rd August 2006 11:53 AM
Copyright ©1999-2013 diyAudio
