Go Back   Home > Forums > General Interest > Car Audio
Old 1st July 2006, 12:10 AM   #11
for some simple reference, read a paper i wrote:
http://www.ee.siue.edu/~cstahl/e592b.pdf
this paper detials the common non-inverting single amplifier biquad in the general case and then expands to two of the three common cases.
case 1 -- equal resistance, fixed gain of 1, Q adjusted by capactiors.
case 2 -- equal capacitance, fixed gain of 2, Q adjusted by resistors.
case 3 -- equal capacitance, equal resistance, Q adjusted by gain.
i didn't cover case 3. for this circuit a high gain makes component tolerance requirements unreasonable. for a general purpose filters i prefer case2, which allows the Q to be adjusted with resistors which are found in 1% tolerance.
now you just need to find a look-up table for the desired Q and F values for the filter you want.
also look into "filter free" by nuhertz. or filter pro ect... filter free will give you up to 3rd order filters.
if only it could be used for good, not evil...
Old 1st July 2006, 03:46 AM   #12
Ok, here they are:
--Subs
Blaupunkt TSw1200
Qes 0.38
Qms 4.06
Qts 0.347
Fs 25 Hz
Vas 4.178 cu. ft.
Ze 4 ohms
Re 3.69 ohms
Xmax 0.22 in.
SPL 90 dB
Pe 200 W
BL 12.5
Sd 0.549 sq.ft.
air volume displacement 0.12 cu.ft.
--Amp
Sony Xplod XM2200GTX
200 WRMS X 2 @ 4 OHM
250 WRMS X 2 @ 2 OHM
500 WRMS X 1 @ 4 OHM
50 - 300 Hz , 12 db/oct Low-pass filter
0 - 10 dB (40 Hz) Low boost
Space I need to work within:
Width - no more than 29"
Heigth - no more than 14.75"
Depth - my entire trunk if needed
Would be best if front of box was at a 79.5° to fit nice and snug against the back of my back seat. My seats fold forward.
Some VERY good info here - http://sparky3489.webs.com/
Old 1st July 2006, 10:24 AM   #13
Filters...which one to use? Post #1
I need a HP filter that cuts off everything below 45 Hz with a 24 dB roll-off.
If you designed PCB's, which would you choose?
1. Two 2nd order Sallen-Key Butterworths cascaded
2. A 4th order Sallen-Key Butterworth
3. Passive RC HP filter
4. Some other filter I didn't mention - please explain
Why may i ask? i hope you know passive subsonic filter make the speaker sound like poo... I mean you could use 600w a/c rated Poyproplene caps and big air ribbon coils and it would still be yukkie sounding. Just to spout out a question on a rolloff without giving the senerio of the rest of the circut does no good if you expect a honest real life agreeable awnser
to awnser your question, use a active filter linkwitz-riley to do a fair job at rolling off 24db.
What you have a Metcal...So do I..
Old 1st July 2006, 06:22 PM   #14
30bandgeek,
Did you happen to see my second post (post #4)?
Oh and two 2nd order Sallen-Key Butterworths in series IS a 4th order Linkwits-Riley (I just found that out myself).
By winISDs calculations, I can pump 70 WRMS to my subs before excursion begins to occur with my current design.
Old 1st July 2006, 07:07 PM   #15
for the purposes listed, a linkwitz-riley filter is not really appropriate. the only advantage is is large band-wagon.
i'd say a typical butterworth filter might be more appropriate, if your going active.
i am not entirely sure, but you should check to see if basic RC filters will work. maybe a C-R highpass on the amp input, and a C-R filter on the amp output.
Old 1st July 2006, 09:30 PM   #16
I don't think I need anything on the output (tell me if I'm wrong) since I'm using a 4th order bandpass bass box. The upper frequencies are already taken care of. It's the lower frequencies (below 45 Hz) at higher wattages (above 70 WRMS out of 200 WRMS possible) the I'm trying to cut off to prevent excursion.
Now if I have the gross dimensions of my box
Vf = .76 cu.ft.
Vr = .87 cu.ft.
tuned at 60 HZ
port dia. 3.94"
port length = 9.54"
Excursion is just below the line @ 200 WRMS with a 4th order Linkwitz-Riley set at 33 Hz my excursion graph looks like this @ 200 WRMS:
Old 1st July 2006, 10:03 PM   #17
i guess i didnt understand the question but i do now.
Personally i like to be able to feel the bass below 45hz, also subsonics make a huge diffreance in how spacial the system sounds, but if it is just a bass machine olny for spl well than, sounds like you know what your doing and good luck
RC filters Sch3mat1c Parts 1 29th April 2011 09:34 PM
FM IF Filters Juergen Knoop Analogue Source 4 30th October 2008 03:35 AM
PSU filters kyrochan Power Supplies 1 2nd April 2005 05:05 PM
PI filters Prune Tubes / Valves 3 26th September 2004 10:16 PM
Filters Mr. Bungle Solid State 2 31st July 2004 06:08 PM
Page generated in 0.10602 seconds (81.10% PHP - 18.90% MySQL) with 10 queries
