cadence ZRS-10 schematic! - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 27th June 2006, 01:14 AM   #1
Default cadence ZRS-10 schematic!
HelP whit Cadence ZRS-10 class D amplifier.
The problem is PWM and protection.
Old 30th June 2006, 09:47 AM   #2
Does that amp have the ICs marked B52/F16?
You mentioned that the problem was in the PWM section. Is that the power supply PWM or the audio PWM?
If the amp has hinged covers like the ZRS9, make sure that the screws are tight. I've seen them fall out several times. Generally they cause damage when they short between components.
Have you checked all of the power semis on the heatsink to see if any were shorted?
Also check for shorted/broken inductors on the output.
cadence power transistor clips dynosaur Car Audio 1 28th July 2015 07:31 PM
LED Model For Pspice, cadence and Orcad juanlara Parts 0 8th April 2009 09:54 AM
Cadence Ultrashock A5+HC tankdime Car Audio 0 18th September 2008 11:35 PM
looking for a pre-amp schematic steamPunk Tubes / Valves 3 3rd August 2008 02:49 PM
NEED SOME 2x 90 V AMP SCHEMATIC Drafance007 Solid State 4 6th December 2002 03:09 PM
Copyright 1999-2017 diyAudio
