Need Help: RF 500S amp with tonns of DC in output
Old 22nd June 2006, 04:04 PM   #1
valterdaw is offline valterdaw  United States
Question Need Help: RF 500S amp with tonns of DC in output
I have an old Rockford Fosgate Punch 500S 2-channel amp, which I really want to return to life. When I first got it, it had all, except 3 FETS shorted in power suply and outputs. Replaced all of them, now power supply is working but output FETS always open, no matter what I tried to do - around 50V in each channel It's suspicios, that both channels are showing exact same behavior.
Gate resistors are fine, couple of drivers (I am gonna cry, they are SMD's ) were dead, subbed them.
I am desperately need some help here. Thank you!
Old 22nd June 2006, 06:42 PM   #2
TO-3 is offline TO-3  Peru
TO-3's Avatar
Send a message via Yahoo to TO-3
Default Re: Need Help: RF 500S amp with tonns of DC in output
Sounds suspicious. If both channels are outputing DC, it may be that a OPAMP in the preamp may be bad. A dual channel OP that is used for both channels might do that. I would start there.
Check out Tube Driver BLUE products at: www.tubedriver.com
Old 22nd June 2006, 07:46 PM   #3
Default Re: Re: Need Help: RF 500S amp with tonns of DC in output
Thanks for the suggestion, I'll try tracing leads and pulling some OP's legs. They are all SMD's At least, If everything fails, I can rip out power supply an use it somewhere else
Old 22nd June 2006, 07:49 PM   #4
TO-3's Avatar
Default Re: Re: Re: Need Help: RF 500S amp with tonns of DC in output
They are not that bad. Add a little solder and then with a traingular Xacto Knife blade heat the leads up and use the Xacto to carefully pry. I do it all of the time.
Old 22nd June 2006, 08:55 PM   #5
Perry Babin is offline Perry Babin  United States
If the output has plus OR minus on BOTH channels, it's not likely in the preamp section. Rockford inverts the right channel by feeding the signal to the inverting input of the differential amp of the power amplifier section. If a preamp level glitch was sending the same errant signal (i.e. positive OR negative DC) to the amplifier sections, the output on one channel would swing to the positive rail while the other channel would swing to the negative rail.
Are you sure that you have both positive AND negative rail voltage to the outputs?
Are the 20 ohm driver resistors OK?
If any one of the 20 ohm resistors is open, you likely have one or more blown driver transistors.
Old 23rd June 2006, 03:35 AM   #6
Fixed! You guys are the best!!! And I am still learning. I went through all SMD transistors, found 2 bad ones; one 20 ohm resistor was bad too (but it looks like new lol). I'll put it in my car tommorow morning, and test it hard on a way to work and back. Thanks a lot!
Need Help: RF 500S amp with tonns of DC in outputHide this!Advertise here!
Newb w/a Bash 500S needs sugg. on Sub & Enclosure deetz Subwoofers 6 12th October 2007 10:29 PM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 06:15 PM
PE 500S coupled with Hi-Vi SP10 braden Subwoofers 11 21st February 2007 04:04 AM
rockford fosgate 500s mike49504 Car Audio 14 20th October 2006 06:04 PM
I2S digital output in Marantz CD4000 and four TDA1541A with balance analog output iklari14 Digital Source 30 18th July 2003 12:57 PM
Copyright ©1999-2017 diyAudio
