Can i ?? - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 18th June 2006, 09:33 PM   #1
Question Can i ??
I have two 10 in subs in my truck i have one amp. I want to install a amp for my highs. can i hook the power, remote and ground from my amp with the sub to the amp for my highs?
Old 18th June 2006, 09:52 PM   #2
Banned
As long as the remote can handle the current, you can remote control any amount of amps you want.
Old 19th June 2006, 11:07 PM   #3
Plz explan more i dont understand. how do i know if it can handle it?? thatks for your help
Old 19th June 2006, 11:35 PM   #4
CBS240 is offline CBS240  United States
CBS240's Avatar
If what you are trying to do is add another amp in your car, the remote has a limited amount of current but should be enough to control the amps on and off. Other connections are the same. Look at the specs on how much current the remote can send in your system, and how much is required. You may also have a crossover to seperate the inputs and it too may have a remote switch. Shouldn't be a problem.
BTW, shouldn't this thread be in Car Audio? mods?
All the trouble I've ever been in started out as fun......
Old 19th June 2006, 11:45 PM   #5
Speakerholic
Cal Weldon's Avatar
Done
planet10 needs your help:
Let's help Ruth and Dave
Old 20th June 2006, 03:08 AM   #6
sss is offline sss  Israel
sss's Avatar
Send a message via ICQ to sss
yes u can.
if you are not living on the edge you are taking too much space
Old 20th June 2006, 05:06 AM   #7
Jexx is offline Jexx  United States
Send a message via MSN to Jexx
Make sure the ground and power wires can handle the additional load. You can normally run up to three amps off one remote out, after that you're in shakey territory where it would be better to just get a relay to boost the signal.
Old 21st June 2006, 02:56 AM   #8
Thank you all for your help. i will try and see what happenes
Old 21st June 2006, 08:53 PM   #9
Connect your remote turn on to a Bosch relay to avoid any risk. The site below can give you all the info you need.
http://www.the12volt.com/relays/relays.asp
Copyright 1999-2017 diyAudio
