Go Back   Home > Forums > General Interest > Car Audio
Old 31st May 2006, 02:56 AM   #1
Wombat2 is offline Wombat2  Australia
Wombat2's Avatar
Default Can this be done?
Would this arrangement cause any problems? Car radio/cassette player and a separate CD player feeding into the same set of speakers. Both units are power up when the ignition is on but only one playing at any one time.
Reason I ask is this arrangment has been working OK for about 6 mths but recently playing a tape and the CD player let out the magic smoke.
David L
Old 31st May 2006, 06:31 AM   #2
lndm is offline lndm  Australia
I once tried to bridge both channels of a stereo amp by soldering their outputs together. They died before I could even connect a source. I would definately use a line level connect from one component to the main component, or use a buffer amp.
Just guessing, there may have been a tiny DC offset between the channels, but with almost zero resistance between them, they would have passed current until they passed out.
Old 31st May 2006, 08:38 AM   #3
Simple answer is no it should not be done.
Something will rapidly or eventually blow.
The active amplifier is driving the inactive amplifier as a virtual short.
Power output for both amplifiers will be poor.
/sreten.
Old 31st May 2006, 12:53 PM   #4
Wombat2's Avatar
Thanks - not what I wanted to hear but what I needed to hear
David L
Old 31st May 2006, 06:49 PM   #5
Stocker is offline Stocker  United States
easy solution, not cheap but easy, is to buy a head unit with tape and CD
or get a portable CD player and put it to the line level input of the tape headunit
Jesus loves you.
Old 1st June 2006, 04:14 AM   #6
You can use relays to switch between sources. If you use common Bosch relays, you will need to use 1 relay per speaker wire.
Pin 30 - speaker terminal
Pin 87a - the default source unit
Pin 87 - the alternate source unit
85/86 switched power/ground to the relays. You may be able to use the remote turn on of the alternate source to switch the relays but 4 relay coils may burn out the remote driver transistor. You could switch the relays with a toggle switch or use a 5th relay to buffer the remote output of the alternate source.
Old 1st June 2006, 02:56 PM   #7
Send a message via AIM to IMPALAMAN1
very nice Perry. Is there a limit on the amount of power you can put through the relay?
linear power/ oz audio/ clarion
Old 10th June 2006, 06:21 PM   #8
Send a message via AIM to ocool_15 Send a message via Yahoo to ocool_15
yes, but they are marked on them and a regular 12V 30A relay is more then enough. A 12V relay at 3A or larger is adequate
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 33.33%)
Copyright ©1999-2013 diyAudio
