subw amp install ? - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 27th May 2006, 12:34 PM   #1
dbaudio is offline dbaudio  United States
Default subw amp install ?
I am going to connect my subw amp input ( hi level ) to the disconnected rear speaker wires. This way I can adjust my subw amp volume with my radio fader control. Is this the correct way to connect or should I parallel connect to the rear speakers ?
Old 27th May 2006, 09:02 PM   #2
xplod1236's Avatar
Send a message via AIM to xplod1236
That would be the correct way. Do not parallel the rear outputs, because you will blow up the headunit. The 2 channels would be shorted to each other, and whatever signal difference there would be between them would result in a big current, which would fry the head unit outputs.
Looking for a Subw for AV & Audio... lsfarzo Subwoofers 1 7th March 2008 11:22 PM
how do I install an LED jdbrocious Parts 7 1st March 2008 12:18 PM
new install maxiboy Car Audio 6 26th June 2005 11:06 PM
LM4780 for SubW samsagaz Chip Amps 11 24th September 2004 02:40 AM
Amp install Help PlEaSe. ebwilliams Car Audio 5 8th September 2004 04:28 AM
Copyright 1999-2017 diyAudio
