DC on the speaker outputs, Lanzar Opti 100 - Page 2 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 1st June 2006, 04:05 AM   #11
The right rear seems like it's being driven 'on' which could explain the offset. The other channel is within the margin of error you stated so it's possible that it is also being driven to -16 volts.
Since you have a set of good channels, you can compare those to the defective channels. It's possible that there is a broken ground or power supply connection. I'd suggest comparing the voltages on one driver board to the other.
If you have a scope or other means of tracing the signal, drive one channel at a time to determine which pins on the driver boards are the signal pins. If you have 4 good signals going into the driver boards, you know that the problem is on or beyond the driver board.If you have negative voltage on the signal input pins of the driver board, then the problem is before the driver board.
Unless there is a broken power supply connection to the positive drivers, it's unlikely that the problem is beyond the driver board because both channels have the same problem.
Users manual to a lanzar opti 6200 Flames_Pastorn Car Audio 15 30th August 2012 10:26 PM
Needs specs for old lanzar opti 100 MatthewS Car Audio 3 16th April 2009 12:00 AM
Help needed, Lanzar opti 2500 Leif Car Audio 25 4th March 2009 03:40 AM
RCA outputs to speaker cables? otokomae Instruments and Amps 9 12th September 2005 12:54 AM
Amplifier Lanzar opti drive 2200 Urosch Chip Amps 1 27th September 2004 11:36 PM
Copyright 1999-2017 diyAudio
