Why not high compliance subs?
Old 21st May 2006, 10:38 AM   #1
Davide82 is offline Davide82  Italy
Default Why not high compliance subs?
Lately I had a try and built a subwoofer for my car.
I used a CHEAP 8" driver with dual voice coils.
Then I powered it with a very small amp... 2x20 watt (no need for SMPS!)
It REALLY shaked the car and make everyone amazed..... you could feel 30 Hz easily and not boomy sound.
the magic? I used an extremely large enclosure, so that efficiency was high at low frequencies.... Alignment was very good and transient respone superb.
Now my question....
I would like not to use my hole trunk as subwoofer.
BUT, if I build a smaller box, the sound gets of course boomy because the driver gets harder to move at all: this is a drawback!
This all happens because the stiffness of suspension adds to the stiffnes of the small air trapped in the enclosure. Efficiency shifts to higher frequencies and we get bad sound.
Do they exist drivers with a very low stiffness so that they can work in very small enclosures while maintining good low end efficiency?
The only one I saw were 20 years old drivers with really soft suspension... I guess they work good there.. but I can't see new drivers (and cheap) similar to these ones!
Why all new drivers are quite stiff?
Old 21st May 2006, 06:00 PM   #2
sr20dem0n is offline sr20dem0n  United States
Send a message via AIM to sr20dem0n
Most modern speakers are built like that. You'd want to look for a speaker with a low Fs (<30) and low Qts (~.4), keep in mind though, if you want a speaker to go low and perform well in a small box, you're going to lose efficiency, bottom line (Hoffman's Iron law, ain't it a bitch?). That means that if you still want it to get loud, you're going to have to feed it a lot of power.
Why not high compliance subs?Hide this!Advertise here!
Active High-pass filter for Horn Subs Eddie Wolve Parts 5 21st July 2009 05:47 PM
Why not high compliance subs? Davide82 Subwoofers 5 21st May 2006 03:36 PM
Satelites/subs containing high end caraudio drivers FE3T Multi-Way 0 5th November 2005 08:57 PM
Looking for some solutions to low cost-high performance Subs Emission Subwoofers 39 18th February 2005 03:02 AM
