Do amplifiers produce voltage without a load? - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 5th May 2006, 07:50 PM   #1
Send a message via MSN to Safe_Cracker
Default Do amplifiers produce voltage without a load?
I always thought that an amplifier would not produce a voltage at the speaker +/- terminal on the amp unless it had a load available, is this true? I was watching a demo on how to set your gains with a DMM when they set all setting flat hu/amp and put the DMM on the amps output to measure a predetermined voltage for a given load but it was all done without speakers connected, so where did the load come from? Any help would be greatly appreciated here is the link also...Polo.
http://mobile.jlaudio.com/support_pages.php?page_id=143
Safe_Cracker :O)~
Old 5th May 2006, 08:25 PM   #2
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
Amps do produce output voltage without a load.
The demo looked correct to me.
I believe you can't do this test with amplifiers equipped with an output transformer.
Experts correct me if I'm wrong.
/Hugo
Old 5th May 2006, 08:29 PM   #3
The reason I ask is because the output varries dependant on load so what load are they imposing to get the readings on the DMM? I can see if all speakers are 4 ohm and it doesn't matter but how is the voltage supposed to vary if there isn't a load present? Polo..
Safe_Cracker :O)~
Old 5th May 2006, 09:00 PM   #4
Netlist's Avatar
This is only a way of trimming a preset regardless of the variation in voltage the load will create.
/Hugo
Old 5th May 2006, 09:47 PM   #5
Did it Himself
richie00boy's Avatar
The load will not affect the voltage under 'normal' conditions. Only when loaded heavily the maximum available voltage will be limited.
I don't see the point of setting things by meter when the speaker sensitivities will negate all of it. You should set levels by ear or SPL meter/spectrum analyser.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 6th May 2006, 12:45 AM   #6
Send a message via AIM to sr20dem0n
If you're after sound quality and/or have plenty of self discipline, sure, but some people just want it loud, and setting the sub amp's gain so that you know when it clips and make sure not to exceed that is one of the best ways to save your equipment.
Old 6th May 2006, 01:39 AM   #7
Sooo what you guys are saying is that the voltage is a constant and it is the wattage that goes up/down with different loads? Excuse my ignorance but right when you think you know it all there is always someone out there to prove you wrong, lol. Polo..
Safe_Cracker :O)~
Old 6th May 2006, 03:02 AM   #8
Duo is offline Duo  Canada
Duo's Avatar
Send a message via ICQ to Duo
Well, what happens is that for the same voltage, different resistances cause different amounts of current; hence ohm's law.
If you set the volume and play on a four ohm speaker and then switch to an eight ohm of the same efficiency, you'll notice it's a lot quiter.
This is because the eight ohm speaker draws les current at that same voltage than the four ohm one did.
So yeah, power will change with load, but that's not based on any changes in the output voltage of the amplifier.
-- Duo, W1ngs, VA7MON, and lesser known handles. --
-- http://www.w1ngselectronics.com -- My Work and Projects --
Old 6th May 2006, 05:22 AM   #9
Originally posted by Duo If you set the volume and play on a four ohm speaker and then switch to an eight ohm of the same efficiency, you'll notice it's a lot quiter.[/B]
Just for the record and to avoid the typical inherent voluntary DIY auto-confuzzilisation:
The above statement is only true for referring to "power efficiency" (dB/W/m). In case of referring to "voltage sesitivity" (the typical dB/2.83V/m mostly used in data sheets) you should not experience any change of output level.
regards
There is no truth. Only incomplete perception...
Old 6th May 2006, 06:22 AM   #10
For most amps yes, for the JL slash amps no, because they actively monitor the subwoofer impedance (only on startup) and adjust the output voltage accordingly, to provide [roughly] the same amount of power at all impedances between 1.5 and 4. PG does the same thing with their Xenon amps.
Voltage spikes under load tstitans Power Supplies 3 13th August 2009 03:01 AM
Voltage Drop Based On The Load OMNIFEX Solid State 29 9th May 2009 02:14 PM
Positive regulator to produce negative voltage? stef1777 Parts 45 8th February 2008 08:46 AM
PS voltage without load duke_tj Power Supplies 5 16th September 2007 07:27 AM
Re: Why voltage drops with very small load? Aaron323 Power Supplies 9 17th February 2006 01:02 AM
Copyright 1999-2017 diyAudio
