Blown IRFZ44N
Blown IRFZ44N
Old 2nd May 2006, 04:56 PM   #21
N-Channel is offline N-Channel  United States
N-Channel's Avatar
Send a message via AIM to N-Channel
Default F10U20DN
These are the output rectifiers for the DC-DC converter. Two positive diodes (common anode) for the (+) rail, and two negative diodes (common) for the (-) rail. This arrangement is very common in car amplifiers. you can replace them with the two following parts from OnSemi (formerly Motorola):
MUR1620CT - Common-anode diode pair for the positive bus
MUR1620CTR - Common-cathode diode pair for the negative bus.
Here are their datasheets:
http://www.onsemi.com/pub/Collateral/MUR1620CT-D.PDF
http://www.onsemi.com/pub/Collateral/MUR1620CTR-D.PDF
These parts are very easy to get, and should serve your purposes fine.
Steve
Old 2nd May 2006, 05:36 PM   #22
cruck00 is offline cruck00  United States
How do you normally test a diode?
Old 2nd May 2006, 06:18 PM   #23
I compared the values for the on semiconductor MUR1620CTR and the fairchild FFPF10U20DN and the values did not match up in some of the categories (I fm, V fm, i R) is this going to make a difference or are they interchangeable?
Old 2nd May 2006, 06:57 PM   #24
Perry Babin is offline Perry Babin  United States
If yours are not physically broken or otherwise defective, there's no reason to replace them.
The 1620ct would be a good replacement. The ctR is reverse polarity (diodes on body of component face outward).
Old 2nd May 2006, 07:22 PM   #25
I am going to test these two diode rectifiers to decide if I need to replace them or not could you please give me an idea of what kind of readings I should get.
Old 2nd May 2006, 07:29 PM   #26
The test procedures for the most common components are on the following page.
http://www.bcae1.com/ampfail.htm
Old 3rd May 2006, 02:11 AM   #27
N-Channel's Avatar
Default Interchangeability and Test Procedures
Perry,
That is an excellent tutorial webpage for car audio, and testing audio components in general. Concise & to the point.
Cruck-
I was not able to access the Fairchild website today (our work CPUs have many firewalls and filters), but the MURs should do just fine. 1620 yields 16A @200PIV. That's 8A per leg of each dual diode.
Steve
Blown IRFZ44NHide this!Advertise here!
Huf75337p3 in place of irfz44n? spooney Car Audio 10 9th August 2009 07:03 AM
Is there a difference in a IRFZ44 and a IRFZ44N? Itsme Car Audio 7 6th November 2007 12:33 AM
IRFZ44N Chip Question? Itsme Car Audio 12 29th October 2007 08:58 PM
need to find out which IRFZ44N to get..help please Wyldhorse Car Audio 2 14th July 2007 11:46 PM
Questions about mosfets IRF3205 IRFZ44N dB-r Solid State 3 6th December 2006 01:36 PM
