dome midrange good or bad ?
Can a 2" or 4" dome midrange be integrated into the front stage of a car audio system along with a conventional 2-way component set ? I'm thinking for location would be: 6.5" mid-range in doors (semi off axis) 1"silk dome in the dash (off-axis using windshield) and dome midranges in kick pods or low in the doors either on or off axis. any thoughts ?
Re: Hmmmm?
klm1 said:
How about 2-2", per side, so's you can get proper ohmage into your system???
Don't see a problem, but a crossover might just be(a Problem)...
efficiency?
Hz crossed over?
power @ clipping?
Proper amp sizing?:cool:
They will have there own designated amp with active x-over, so the mechanics of the system will be ok, i'm concerned with the improvement or destruction of the sound stage. the dome midrange freq will be playing the primary vocal range correct ? so, will they dominate or help staging?
