I've got a Phoenix Gold QX4150 4 ch. car-amp and this are using the "old" HA4741 op-amp in the input/ filter stage.
The sound from this amp is so and so...
Considering the "741-family" not very good for audio-use, I want to replace theese op-amps...
I was thinking about MC33079. I can get theese from SGS-Thomson, and ON-semi, would the manufacturer have an inpact on the sound ?
Is there any other Quad op-amp's available that would be better than the MC33079 ??
Lyra
Lyra
Unless the old op-amps have failed, don't look for a significant change in the overall sound of the amp. You may get slightly less noise but there should be no change in sound.
I've used both the MC33079 and the OPA4227. The 4227 has lower noise figures but is not always a good direct replacement due to instability in some circuits. If you don't have an oscilloscope to check for oscillation, I would suggest that you use the 33079.
Don't use the OPA4228 in a buffer or filter circuit. It's a good op-amp but it is not stable in a unity gain circuit.
MC33079 is a quad version of LM833 and it's quite a good low-noise op-amp for its price (it's also available as "LM837").
Anyway, there are thousands of op-amps that will show better specs on paper than a 741. You could even just put a TL074 as well... But, is a change really required?
