Go Back   Home > Forums > General Interest > Car Audio
Old 10th April 2006, 11:44 PM   #1
Default Need A Resistor Value
I received this amp, mtx 8100d. The problem was that it had both power supply resistors are shot. I replace them with 68ohms, but i think the value are wrong. Because i get a hissing sounding coming from the transformer. I know rockfords have this problem, but usually mtx are very quiet amps.
there r435 and r436
Old 11th April 2006, 05:02 PM   #2
niteowl is offline niteowl  Canada
Hi swordfish689
That value should work fine. You can almost use any value from 10 to 100 ohms. try pressing your finger on the transformer in differant spots and see if the sound go's away. I've had to do this with rockfords then if it quiets down, I would put some glue on the windings to suppress it. Does the amp work?
Martin
Old 11th April 2006, 06:00 PM   #3
In the 1501 that I have here, they are 39.2 ohms.The board layouts look the same and the resistors have the same designations so the value should be right.
Some of those amplifiers are extremely noisy. After repairing it, run it hard. The power supply and the output FETs should all operate at roughly the same temperature. If either set of FETs is running significantly hotter than the other, you may want to check it a little more thoroughly.
Old 12th April 2006, 12:07 AM   #4
lndm is offline lndm  Australia
Not sure from the picture, but it looks as if the capacitor has expanded. Bad capacitors can hiss (not sure if this is what you meant).
Old 12th April 2006, 05:34 PM   #5
Thanks for the replies. The only thing that i replaced were the 8 power fets, 2 resistors near the fets, and one diode that seemed to be overheated, it still worked, but i didn't want to take any chances. It turns on and works, the only thing i don't like is the sound of the transformer, making a loud hissing sounding. Also it has no gain, its full all the time, the first time i connected it to my sub it rattled the windows. Scared the **** out of me. I need to check the op-amps. Thanks again.
Old 12th April 2006, 06:34 PM   #6
If the RCA jack shield 'bell' isn't soldered to the RCA jack 'frame', solder them together. Apply heat from the outside of the frame and apply solder to the inside of the frame. If the shield ground is not solidly connected, the amp will oscillate at ~100hz at full power. The newer RCAs are soldered.
The amps do have problems with failing op-amps that cause low frequency oscillation but I've never seen a failed op-amp cause full power oscillation.
Old 12th April 2006, 10:38 PM   #7
Did you say it was the transformer making the sound? Is it a buzzing sound? If so, this is probably not a problem, many xfmrs buzz a little.
Which resistor type for emitter resistor? sajti Parts 25 8th April 2009 06:12 AM
What resistor should I use? Rob11966 Tubes / Valves 1 2nd March 2009 09:52 AM
Why this resistor? Shel-e-bean Everything Else 28 4th August 2006 04:57 AM
Help with Resistor Please saabie22 Parts 5 2nd February 2005 09:39 PM
screen-plate resistor and grid leak resistor metebalci Tubes / Valves 4 26th February 2004 03:18 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
