I clonning Milbert BAM230/235 Car Tube Amplifier Supply I clonning Milbert BAM230/235 Car Tube Amplifier Supply - diyAudio
Old 10th April 2006, 05:51 AM   #1
ANALOG GUY is offline ANALOG GUY  Malaysia
Send a message via MSN to ANALOG GUY
Default I clonning Milbert BAM230/235 Car Tube Amplifier Supply
From my posted at Electronics and Tube forum
http://www.diyaudio.com/forums/showt...973&highlight=
and
http://www.diyaudio.com/forums/showt...262&highlight=
Now I succesfull for fixed my Milbert Car Tube Amplifier by changing PQ35/35 to EI40 choke & step-up ferrite core, I wondered about quality of new core.
I learning its operation and redesigning its PCB (some concept from my master : MR.DAVID LUMANAUW)
I decide for build new Tube CAR Amplifier with 20WATTS Single Ended Class-A : 211 TUBE.
If anybody interested please notice and look this post !!! I shall d o it !!!
Regard
analog guy
Old 10th April 2006, 06:27 AM   #2
Default My repair collection (Haaaa)
Left channel of BAM230,it used PCB from Bering EA-230 but Milbert had modified some value of input & phase spritter.
Old 10th April 2006, 06:31 AM   #3
Default My repair collection (Heeeee)
Right channel of BAM230.
As same as left channel.
12ax7 + 12at7 + 6sn7 + 6jn6
Old 10th April 2006, 06:33 AM   #4
Default Power Supply Section (Broken Core)
Now I changed PQ35/35 to EI40 (not in photo)
The best concept for me is
1.Carbon resistor for tube aplication
2.High FRQ core
3.Teflon insulated wire
4.Low current power amplifier
5.Electrocube Couping Capacitor (I seen in LAMM)
Old 10th April 2006, 06:42 AM   #5
Thumbs up BAM230 zoom out view
In my country : BAM230 it's about 650USD for 2nd hand market.
I seen some intested concept about HV supply for car tube amplifer but they're there's no (-)bias and filament supply on board, How about this concept ?
http://www.audiohobbyist.com/diypart...kit/carpsu.htm
Regard
analog guy
Old 7th May 2006, 04:59 AM   #6
Thumbs up This's Bottom Layer Pcb
I think it's quite complex PCB with output transformer included on PCB.
Could I use EL34 instead of 6JN6 ?
Now I can't drive 5.75" DYNAUDIO 15MA SPEAKER with MILBERT BAM-235, How do I modify this amp for this mission ?
Regard
ANALOG GUY
Old 4th June 2008, 08:02 AM   #7
rush1 is offline rush1  Indonesia
Default Re: I clonning Milbert BAM230/235 Car Tube Amplifier Supply
and
Regard
analog guy
Whew, just found this thread, did you ever tried built the 211 tube car amplifier? I am interested in it.
Old 6th June 2008, 03:04 AM   #8
Hotsauce is offline Hotsauce  United States
My experience with 845 tubes is that the filiment is extremelt fragile while hot.
The 211 may be fragile as well.
6JN6 are very hardy, and inexpensive.
If you're building an amp from scratch for a car take a look at tubes that were used in avionics. Loctal base will help keep the tube seated.
John C.
Owner of 3 Milberts.
Old 22nd December 2013, 02:40 PM   #9
bucanian is offline bucanian  Brazil
Hi Anolog, I am interested in cloning the amp, BAM-235, how can we do this? Thank you.
Old 29th May 2016, 04:29 AM   #10
Precisionmike is offline Precisionmike  United States
I realize this is an old post. Did anything become of cloning a Milbert?
I clonning Milbert BAM230/235 Car Tube Amplifier SupplyHide this!Advertise here!
Does anyone has Milbert BAM230 tube car power amplifier ANALOG GUY Tubes / Valves 4 19th January 2016 08:32 PM
Copyright ©1999-2017 diyAudio
