#11 |
With the M455, I could take the 4 channels and run those fore and aft, V-berth & cockpit. Then I could preout for the main cabin another four channels, right?
Why seperates instead of coaxial? |
#12 |
yes you could run speakers of the m455 I prefer usuing an amp as no hu Ive heard has the power to suit my taste. The components are a personal preference (I think they are a little better than coaxials) but coaxials will work just fine also. As for the speakers in the salon and the v-birth I would just use speakers of your choosin.
WHAT ____________ |
#13 |
Oh and I forgot to mention the other reason I recomended the M455 is it does have a aux input you could use with a standalone xm raidio.
WHAT ____________ |
#14 |
Well, it's started. I bought a couple of those Aura amps on closeout. I guess the next issue is speakers.
What about using the forward bulkheads as baffles? The rear of those bulkheads are hanging lockers. Roughly, I guess their volume to be about 6 or 8 ft^3. your thoughts? |
#15 |
Is this in the v-berth?
WHAT ____________ |
#16 |
No sir, these are for the salon. This is the bulkhead that divides the v-berth from the main cabin. Both port and starboard sides of the bulkhead are framed out for hanging closets.
I have two options. The first is to turn the bulkhead, P & S, into a baffle for midwoofer & tweet. The other is to build an enclosure ~ like HT fronts. The boxed speaker would subtract from the asthetics of the furniture. I sound like a wife... I wonder what she thinks of the 7' line arrays and Tuba 18's in the den??? The V-berth will also require an interesting solution... 3" or 4" drivers... PS Thanks for your interest in this project... I'm baffled by the car audio stuff. |
#17 |
the hanging lockers would probably work ok (depending on the speaker) Most marine (or car audio) speakers would probably do well in this situation
WHAT ____________ |
#18 |
Now what?
Purchase a pair of 6" component Focals.... the V2's. I will mount those facing aft into the main salon on the forward bulkhead. I bought the Aura 4 channel 50w/c amp. I will run the Focals from two of the channels and bridge the other two channels for the sub. So what for sub? The only suitable location (for a stealthy install) is in the settee facing midships. The speaker would be mounted a couple of inches above the cabin sole. There is about 5 or 6 cubic feet behind the face of the settee. It would be easy to seal the compartment. This location will accomedate a 10" driver. I am looking at some of the subs that are suited to this size of sealed enclosure... Aurum Cantus AC-250F? Dayton RSS265HF? HiVi D10.8? Should I be looking for a dual voice coil? THANKS |
| Boat Amp! Sanyo LA4508 8.5w chip | oublie | Chip Amps | 6 | 28th June 2009 06:47 PM |
| Making some tower speakers for my boat? | loudsubz | Multi-Way | 10 | 23rd December 2007 12:54 AM |
| Planet 10 and others... Fostex OB boat audio??? | chipco3434 | Multi-Way | 1 | 24th March 2007 08:13 PM |
| Wakeboard Boat Speakers | lbz99smp | Multi-Way | 2 | 9th March 2006 11:32 AM |
| Page generated in 0.09412 seconds (81.55% PHP - 18.45% MySQL) with 10 queries |
