how did you build your box
Old 7th April 2006, 03:41 AM   #1
jpark is offline jpark  United States
Lightbulb how did you build your box
ive heard a lot of different ways and stories when it comes to box building. what about you, what kinds of things do you consider / how d o you go about it when building the perfect box, for SPL and SQ both?
Old 7th April 2006, 11:10 AM   #2
Clipped is offline Clipped  Thailand
Send a message via MSN to Clipped
i use a sliding slot port with a predetermined length to find the best surface area, but it almost always ends up with 'approx'
12-16 sqin" of port for every cubic foot....as far as length, you just have to experiment to see what tone you want the sub to take...
a bit of advice while actually building it, if your not planning on using wood glue and just using screws....get the cuts as straight and clean as possible (pre-cut) is good, then use super glue to keep the pieces in place, then drilling the holes for the screws will be much easier and much much much faster...
if you use a jig saw to cut the straight lines, forget the super glue...there will be gaps and it wont work like it should.
the super glue is only there to keep things in place as you drill, not for strength...
always try to keep the airflow as even as possible for all subs when porting...
how did you build your boxHide this!Advertise here!
I want to try and build my own DAC gareth Digital Line Level 3 3rd July 2009 03:20 PM
ZV9 build ingi Pass Labs 8 6th August 2006 02:40 PM
build my first full ranger,let's build another one:a small fullrange high end pc-spea then_dude Full Range 2 30th November 2005 07:54 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 09:52 AM
Copyright ©1999-2017 diyAudio
