Transistor a1023?
Transistor a1023?
Old 5th April 2006, 02:34 PM   #1
shiipseki is offline shiipseki  United States
Default Transistor a1023?
I have a Treo ssx1500.1 amp that has a burned transistor a1023, but i cant seem to find it anywhere.. Help me out guys
Old 5th April 2006, 02:39 PM   #2
anatech is offline anatech  Canada
anatech's Avatar
Transistor a1023?
Hi shiipseki,
That's a 2SA1023. 70V, 100mA, 250mW, Hfe=200 ish. A 2SA970 would work well as a sub, the beta is a bit higher.
-Chris
Old 5th April 2006, 03:07 PM   #3
Thanks for the quick reply!
Where can I purchase the 2SA1023?
Old 5th April 2006, 03:16 PM   #4
anatech's Avatar
Transistor a1023?
Hi shiipseki,
A couple questions now spring to mind.
Do you have the schematic or know what this part does exactly (might be more problems)?
How much experience do you have at servicing amplifiers?
This is a common Japanese part. Mouser or Digikey may have it. Jan numbered parts do not have the same pin out (not even close to the same parts). If you buy ECG or NTE parts, then just run over it a few times. The result will be similar, but running over it is much more fun.
-Chris
Old 5th April 2006, 04:27 PM   #5
I do not have much experience at all...
I'm just trying to replace parts that seem to be burned...
Is this a good idea?
Old 5th April 2006, 04:38 PM   #6
anatech's Avatar
Transistor a1023?
Hi shiipseki,
Not generally. You could get lucky, or cause more damage. Proper servicing is a bit more involved than that.
If you have a friend who knows more, I'd enlist his help.
-Chris
Old 5th April 2006, 06:38 PM   #7
Perry Babin is offline Perry Babin  United States
http://www.mcminone.com/search.asp?keyword=2sa1023
I've used the KEC brand with no problems.
In some of the class D amps, the 2sa1023 and 2sc1027 transistors are used as drivers in the audio section. When used there, the transistors (a1023 or c1027) may be connected directly in parallel with no resistors. This means that the transistors must match very closely to assure equal current sharing. If your amp has this type of circuit design, replace both parallel drivers at the same time.
Check the other drivers in the area as well as the transistors that they drive (output FETs or power supply FETs). If there are zener diodes in the driver section, check them. They are likely 12 volt zeners. If the amp appears to be working properly, measure the voltage across the zeners. Sometimes they short or leak (electrically) which reduces the drive voltage and will cause the outputs to run hot.
When powering the amp up after replacing the parts, use a current limiter in the power supply line or use a small fuse (~10 amps). Clamp the amp back into the heatsink before applying power to it.
Old 6th April 2006, 11:03 PM   #8
anatech's Avatar
Transistor a1023?
Hi Perry,
KEC ?
I've heard of KSA, KSC ..... Just Koren manufacture. If KEC is any type of replacement brand - avoid.
-Chris
Old 6th April 2006, 11:45 PM   #9
I would never knowingly recommend something like ECG or NTE. KEC is the manufacturer as far as I know. The top image is the original that I pulled from a JBL 1200.1. The second image is the KEC replacement from MCM. The third image is a transistor that I received from JBL. They look the same to me. The only difference is the date code and the dot which likely indicates that it's lead free.
http://www.bcae1.com/images/img192.jpg
http://www.bcae1.com/images/img191.jpg
http://www.bcae1.com/images/img193.jpg
Old 6th April 2006, 11:47 PM   #10
maybe i'll just send it out for repair you guys know any good places with decent price?
Thanks, I appreciate all the help
Transistor a1023?Hide this!Advertise here!
Can bias transistor mount on top(body) of output transistor?? Leolabs Solid State 26 28th April 2016 10:34 PM
503 transistor dazling69 Solid State 5 18th September 2005 09:03 PM
Best Transistor? samsagaz Solid State 13 18th October 2004 09:22 AM
Transistor ID EchoWars Solid State 6 24th January 2004 12:45 PM
Need Help ID'ing Transistor Tom D Solid State 9 20th September 2002 11:30 PM
