Go Back   Home > Forums > General Interest > Car Audio
Old 4th April 2006, 12:08 PM   #1
Default Can multiple 6x9 fill in for a sub?
I already have a pair of JBL CS396e (in the rear tray of my car). My pioneer deh-mp4750P player has a 4 channel amp out of which only rear 2 channels are currently used. I am satisfied with the sound except for bass. I donĄŻt want to go for a sub. Can I put another pair of JBL CS396e in the same rear tray and power them with the amps for the front to fill the missing bass? The player also has a parametric equalizer so I could set the EQ boost at 40Hz.
Although the amps are about 20 Wrms per channel, there could be sufficient bass since the JBLs are quite sensitive at 91db.
Has anyone tried this approach?
Thanks in advance,
Goldy
Audio enthusiast/hobbyist
Old 5th April 2006, 12:36 PM   #2
fury is offline fury  Australia
http://vibeaudio.co.uk/index.asp?pag...=p-qb69-f.html
Try those on for size...
Awesome 6x9's. The only ones i'd ever consider using.
They give out a decent amount of bass... Still not enough to out do a decent sub, but still better then no sub.
Old 5th April 2006, 11:38 PM   #3
Send a message via AIM to Staticjeep
i still think you should buy a sub. maybe 1 10 will do the job if u dont want too much bass
Old 7th April 2006, 11:15 AM   #4
Clipped is offline Clipped  Thailand
Send a message via MSN to Clipped
i once had 4-6x9's in my back deck with 400 watts...sounded like 2-10's...but could only get so loud.
using a subsonic filter is pretty important, cut out the lowest frequencies around 35hz and below and they can get alot louder...6x9's cant really play those notes with authority to well anyway...
i had mine hi-passed at 50 hz and up....so they werent actually mimicking a 'subwoofer' but a normal 'woofer'...
On Damping, Voids and Fill staggerlee Full Range 5 5th October 2007 12:11 PM
Deriving rear fill from crossovers angeloPB Car Audio 6 12th March 2006 07:28 PM
the rear fill ch of the jl 500/5? MyNameIsJake Car Audio 2 13th January 2006 05:18 AM
If I use 1g dammping fill Vb1= Vb - xx litres DariusM Multi-Way 3 13th December 2005 08:08 PM
Internal fill theoracle Full Range 0 5th December 2004 05:34 PM
Page generated in 0.07082 seconds (73.92% PHP - 26.08% MySQL) with 10 queries
