Where 2 find Schematic DIY Car Tube Amo 30W at least ?
Old 24th March 2006, 12:38 AM   #1
calico88 is offline calico88  Indonesia
Default Where 2 find Schematic DIY Car Tube Amo 30W at least ?
I wonder if someone could help me.
I'l looking for 30Watt at least per channel car tube amp schematic DIY ?
any advice please ...
I've been googling but no luck
rud
be tube
Old 24th March 2006, 12:42 AM   #2
trusound is offline trusound  United States
trusound's Avatar
Send a message via AIM to trusound
not sure if this helps...the only production all tube that is 30 watts + is the HSS Fidelity HT230 which is a dual mono class a all tube
Old 24th March 2006, 12:47 AM   #3
Monoblock is fine, I guess monoblock Is better
rud
be tube
Old 24th March 2006, 10:22 AM   #4
lumanauw is offline lumanauw  Indonesia
diyAudio Moderator Emeritus
lumanauw's Avatar
Send a message via Yahoo to lumanauw
Milbert BAM230 seems will fit your search
This amp has tube audio section like David Berning's EA230
Google for "Berning EA-230" for more information about this amp
Old 24th March 2006, 11:20 AM   #5
MelodiMaster is offline MelodiMaster  Indonesia
Guy's this dude wants a DIY project for car amp.
I think it is hard to build a DIY Tube car amps. Unlike a Transistors amp.
Beside a full tube configuration or a hybrid configuration?
A hybrid configuration is more make sense.
A Fully tube configuration for some people still a big problem.
Some tube need more than 300volts to power up the Elektron and where did you find that energy in 12 volts area? I know we can build inverter. but mostly some problem will occur.
I know one people that try to build a fully tube DIY car amp and not succed. The result a highly noise comes in the speaker. He try to made some modification but the end result is an electric shock comes from the interconnect
Hard but im not saying inposible.
Old 24th March 2006, 01:17 PM   #6
lumanauw's Avatar
That's the point. Like EA-230 above, somewhere in the pcb there are -200V and +430V. If you touches that 2 point, you can experience what's being flowed by 630V like. It's not only dangerous, it is LETHAL.
So,.......don't blame google if you don't find any DIY car tube amp. In the current DIY world now, even if you put "Build at Your Own Risk" before the project, if anything happens to you, the author will automaticly feel guilty just by putting the information for public.
Where 2 find Schematic DIY Car Tube Amo 30W at least ?Hide this!Advertise here!
Where to find NAD 218 schematic?? Leolabs Solid State 23 26th December 2017 03:53 PM
can't find valve art tube - and glowey tube pic wicked1 Tubes / Valves 23 10th February 2009 01:54 AM
Schematic for Gm70!Where to find it! lamant Tubes / Valves 6 15th December 2006 07:11 AM
12AT7 Pre-amp schematic, where to find? Anaksulnamun Tubes / Valves 11 18th September 2005 01:13 PM
