Go Back   Home > Forums > General Interest > Car Audio
Old 10th March 2006, 07:11 PM   #1
Default 1969 Beetle with 35 Amp Generator
The title says it all, I need to toss a HUGE system (-; in this bad boy. I am concerned about power draw. Will a couple of nice capacitors for my AMPS be enough to resolve this?
Old 10th March 2006, 10:01 PM   #2
I don't know how you define 'huge' but the only real solution is to replace the generator with an alternator of sufficient size.
When used in the often recommended ratio of 1F/1kw, caps will do virtually nothing Extra batteries are good for extended periods of operation with the engine off but they will always be an extra load on the alternator when the engine is running. An alternator is the only device that can supply power without needing to be recharged. It's also the only thing that can keep the voltage high when the current demand from the amplifiers is high. Capacitors can help to maintain voltage for a tiny fraction of a second but not much more. Batteries will do very little to help maintain voltage until the voltage gets below ~12 volts.
Old 11th March 2006, 08:22 AM   #3
dnsey is offline dnsey  United Kingdom
Whether you use capacitors, an alternator or anything else, don't forget that the power is ultimately supplied by the engine.
A '69 Beetle isn't exactly overpowered in the first place, so once you've fitted your sound system, it may be loud but it'll be SLOW (and thirsty) too!
Old 11th March 2006, 05:45 PM   #4
Default Well
I have decided to go ahead and try it anyway, I am just using the BOSCH generator and slapping in a battery system. Will let you know how it goes.
Old 11th March 2006, 06:07 PM   #5
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
High efficiency loudspeakers and enclosures will be of great help when available power is limited, because an increase of just 3dB/W in sensitivity will half the power requirements.
Old 17th March 2006, 10:49 AM   #6
Batteries have 10 times the recovery speed of caps.
Back in the "old" days,we used to have VW alternators custom rewound.If I remember right,they put out about 60 amps.
Pioneer cs 77 speaker c., 1969 bobhowell Multi-Way 3 3rd July 2009 04:07 PM
TIM generator darkfenriz Solid State 10 6th May 2007 11:11 AM
How many IC's for single RST generator? ezkcdude Digital Source 2 27th July 2006 04:07 PM
SME 3012 circa 1969 cueing mechanism patientdog Analogue Source 6 23rd April 2004 05:14 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
