I just bought a Mundorf 50/96 amp power supply. I want to use this for listning and tuning my system without running the motor.
I would like to be certain how to use this before I start to do anything. Must I first disconnent the +/- cables from the battery and hook them directly to the power supply? Or can I just hook the +/- from the power supply directly to the battery just like with jumper cables? The total Amp draw at maximum strain should not be more than around 80 Amps. Thanks once again guys for the help. |
#3 |
Thanks alot. Now I can get started.
P |
#4 |
Did you have any problems with the power supply at 240ac? noise or RF? i am very interested in your project.
Tap or Snap, it's up to you. |
| Negative volts and grounding in bench power supply | falcott | Parts | 11 | 29th April 2011 04:42 PM |
| how to use 30 volts DC instead of split power Supply | ali_moinuddin | Pass Labs | 5 | 2nd April 2008 11:34 PM |
| power supply question.... too many Volts? | akimball442 | Tubes / Valves | 3 | 18th February 2007 05:12 PM |
| 16 volts 3A regulated power supply help | sunny | Power Supplies | 30 | 3rd November 2006 12:51 AM |
| Volts AC rating in power supply caps | rick57 | Tubes / Valves | 6 | 28th May 2006 01:59 AM |
| Page generated in 0.07787 seconds (74.48% PHP - 25.52% MySQL) with 10 queries |
