How to use a 220 Volt power supply at 12 Volts in the car?
Old 5th March 2006, 12:08 PM   #1
Mr. Old School is offline Mr. Old School  Germany
Send a message via Yahoo to Mr. Old School
Default How to use a 220 Volt power supply at 12 Volts in the car?
I just bought a Mundorf 50/96 amp power supply. I want to use this for listning and tuning my system without running the motor.
I would like to be certain how to use this before I start to do anything.
Must I first disconnent the +/- cables from the battery and hook them directly to the power supply?
Or can I just hook the +/- from the power supply directly to the battery just like with jumper cables?
The total Amp draw at maximum strain should not be more than around 80 Amps.
Thanks once again guys for the help.
Old 9th March 2006, 07:52 AM   #2
DigitalJunkie is offline DigitalJunkie  United States
Send a message via AIM to DigitalJunkie
Just parallel it like you would with jumper cables. :-)
Old 9th March 2006, 08:23 AM   #3
Thanks alot. Now I can get started.
P
Old 10th March 2006, 12:11 AM   #4
Iron-Wizard is offline Iron-Wizard  United States
Iron-Wizard's Avatar
Did you have any problems with the power supply at 240ac? noise or RF? i am very interested in your project.
Tap or Snap, it's up to you.
How to use a 220 Volt power supply at 12 Volts in the car?Hide this!Advertise here!
Negative volts and grounding in bench power supply falcott Parts 11 29th April 2011 03:42 PM
how to use 30 volts DC instead of split power Supply ali_moinuddin Pass Labs 5 2nd April 2008 10:34 PM
power supply question.... too many Volts? akimball442 Tubes / Valves 3 18th February 2007 04:12 PM
16 volts 3A regulated power supply help sunny Power Supplies 30 2nd November 2006 11:51 PM
Volts AC rating in power supply caps rick57 Parts 6 28th May 2006 12:59 AM
