Go Back   Home > Forums > General Interest > Car Audio
Old 2nd March 2006, 08:51 PM   #1
kirkie is offline kirkie  Portugal
Default Can anuone help....
high! Iīve got a panasonic cq-rdp383n and it have got two rca entries to a cd box changer,wich i donīt have, and iīve tried to connect my ipod to it but the auxiliar mode of my panasonic didnīt recognised him..is just like anything was connect to the radio... can anyone help me? thanks
Old 2nd March 2006, 09:03 PM   #2
Send a message via AIM to DigitalJunkie
I'll bet there's a small (DIN type?) plug somewhere for the CD-changer also?
The CD-changer 'talks' to the deck on that plug,and uses it for control,etc.
Sometimes it simple to 'trick' the deck,like adding a resistor across two pins,etc.
Most of the time it isn't,and the Changer and Deck use a specific format (I2C,or something.) so you'll need some IC's and stuff to tell it to activate the CD-input.
There are companies that make little plug-adapter things that you can plug into your deck and make use of the extra inputs,Google should help you find some.
Also,There might be a "homebrew" version of one,depending on the brand/model of the deck..Google should help you there too.
I've seen a few projects around online,so it can't be too hard,but it probably depends heavily on the model of deck.
Old 3rd March 2006, 06:37 AM   #3
Default Thanks
Thanks for the help! is a 8 pin din plug. Can you tell me wich holes and should i try to connect with a resistor? about the way the resistor is a 5 kohm? Thanks a lot
Old 3rd March 2006, 08:52 PM   #4
Send a message via Yahoo to Harmoniz
Hi
If you are trying to attach the iPod to the HU, another way (slightly costlier) is to get a preamp which usually has 2 sources for input.
The preamp also has an auxillary input where the iPod can be plugged in and totally bypass the HU.
Then you can use the selectable switch on the faceplate of the preamp to determine the source, ie. HU or the Aux (iPod)
Hope this helps.
Cheers
<Finding the balance between SQ and SPL>
Old 26th January 2007, 09:43 PM   #5
sandgyp is offline sandgyp  United States
Default preamp
I had thought abought using a preamp but where would you get a 12v one?
Old 21st February 2007, 08:55 AM   #6
Default Re: preamp
I have one schematic of one..
Old 21st February 2007, 02:24 PM   #7
Thanx...I appreciate that!
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright Đ1999-2013 diyAudio
