connecting sub with frontspeakers ?
Old 16th February 2006, 11:28 AM   #1
ROVSING is offline ROVSING  Denmark
ROVSING's Avatar
Default connecting sub with frontspeakers ?
I'm rather new in carhifi i got 2 pairs of loudspeakers in my car but no special sub connection is it possible to combine the frontspeakers with a sub ?
Would it be easy to make a crossover wich takes care of that ?
I assume that the sub should be connected to both outputs but how ?
My plan is to build chipamps into the car based on either LM 3886, LM 3875 or OPA 549, i have allready started building my SMPS fore this based on SG3525, but till i reach that point i would like to get my sub installed temporarily- if possible.
Eventually schematic would be very helpfull.
Suggestions fore 2+2+sub amplifiers and wich chip to prefere would be helpfull too, thanks.
Frandsen
Old 16th February 2006, 11:59 AM   #2
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
In the absence of line level pre-outs you need to tap off the speaker connections and use these to drive your amp. In front of the amp you should add a L+R summing circuit and an active filter, 2nd-order Butterworth adjustable 60-120Hz should do the job.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 16th February 2006, 12:55 PM   #3
ROVSING's Avatar
there is line level preouts and i've found an adjustable Sallen-key butterworth filter 45-225 hz somewhere else in this forum, but could you please explain what L+R summing circuit is ?
eventually guide me to a link that explains it ?
Can i use preouts and loudspeakerconnections at the same time ?
thank you for helping me so far.
Frandsen
Old 16th February 2006, 01:18 PM   #4
Did it Himself
It mixed the left and right channels to produce a mono output. Google for 'virtual earth summing op-amp' or look at http://sound.au.com
Old 17th February 2006, 09:27 AM   #5
ROVSING's Avatar
Thank you for the help, i found a good link explaining most of the things that i can use fore this project.[URL=http://--http://www.eng.yale.edu-ee-labs/morse/compo/sloa058.pdf[/URL]
27 seven pages explaining a lot about op amps.
Now i got something to study this weekend.
Frandsen
connecting sub with frontspeakers ?Hide this!Advertise here!
need help connecting pro amp to pc joka22 Solid State 23 6th July 2007 12:43 AM
connecting a pot jarthel Parts 8 3rd September 2006 09:54 PM
Need help with connecting OPT. juoto Tubes / Valves 1 17th January 2006 06:51 PM
