My favourite people at the Volkswagon dealership spent a good 4 hours (@ ~$80/hour!!) trying to figure out why my car battery was running down, and finally they discovered that it was my monsoon amplifier. They told me that it had to be replaced, and a new unit would run me $700.
Now, it seems that thier solution to everything is to order expensive new parts. Im wondering if there is anyway to diagnose this problem, and possibly fix it, without resorting to buying a completely new amp. I know a little bit about electronics, and am handy with a soldering iron, but I am no electrical engineer. If some of the experts at this forum could give me some ideas, or staring points, that would be awesome. It definately is the amp, because the car battery does not drain when I disconnect the unit. Cheers, Nate |
#2 |
It looks like the following repair center services those amplifiers:
http://www.carstereohelp.com/ If you can't get it properly repaired and it works otherwise, you may consider installing a relay on the power wire. Connect the relay so that it disconnects power when the ignition is switched off.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
Car dealers *never* repair electronics, their "technicians" are just trained to keep replacing electronic modules by new ones until the problem is solved (sometimes, good modules are replaced too).
So if you don't want to expend a whole lot of money, you have to find some smart electronics technician willing to repair it. I do that kind of work sometimes and I would be glad to try to repair that amplifier, but unfortunately I live in the opposite side of the world Try to find someone in your city. |
#4 |
IS YOUR AMP SWITCHING OF WHEN YOU SWITCH OF YOUR IGN?IS AMP GETTING A SWITCHED SUPPLY FROM THE HEAD UNIT.
#5 |
Well, I found a cheap replacement amp, and guess what? The problem still occurs.
It seems to me that perhaps the head unit is at fault for switching on the amp when it is not supposed to or not switching it off. Is there any way to tell if the amp is on? The monsoon system on the jetta seems to be a strange beast. From what I understand, the amp turns on/off automatically (or is supposed to) when it senses a signal from the HU. Also, apparently the amp is more of an active crossover than an actual amp... I think the head unit is responsible for most of the amplification. The fact is, when I disconnect the amp, the problem doesnt occur. So any ideas why the amp is draining the battery? Thanks again. |
#6 |
Wires that go to any amplifier:
+12V Ground Input Signal(s) Speaker Output and the important one for you: "Remote" The remote lead from a head unit goes to a connector on the amplifier, usually near the power inputs. When the head unit turns on, the remote lead should have +12 volts on it. When the HU shuts off, the remote should go to ground potential. IF the head unit is switching the remote lead properly, the amplifier should turn on/off with the HU. Do NOT wire directly from +12V to the Remote input on an amplifier or you will....drain......the.......
Jesus loves you. |
#7 |
Is there a aftermarket head unit in this car ? Does the stereo run fine when you are driving around ? I have fixed and see this issue. It is caused buy the deck not turning the power amp off when the igntion is turned on.. to me it sounds like this..
Deck is controling the amp remote turn on. It might be possible to remove the amp's remote turn on wire and see if it still drains the power if it does then change the remote turn on wire to the ign wire. See if this helps.
Baby Danika, Born January 20th 1:54am.. http://itsparks.dyndns.orgMix a LittleUntangle&Opendns.org Perfect.. |
#8 | |
Antoine http://dmsaudio.ca/ |
#9 |
try a different aternator your cars battery my not be recharging and thats causeing it to die.
or you could try a capacitor. But it could drain your battery faster than the amp does now. |
#10 |
Maybe a relay on the 12v line switched by the head unit could work.
| +/-18V & +48V from a battery | jeppix | Power Supplies | 23 | 20th November 2009 05:26 AM |
| Battery Charger for 15V Li-ION Battery Pack ??? | Jan Dupont | Parts | 2 | 11th April 2009 03:18 PM |
| Filter cap not draining smoothly...? | ElectroAcoustic | Parts | 6 | 18th December 2006 06:37 AM |
| How to prevent capacitor draining? | rs1026 | Chip Amps | 20 | 25th October 2004 09:01 AM |
| Battery | VoLCoM | Parts | 1 | 17th August 2003 09:45 AM |
| Page generated in 0.12393 seconds (79.44% PHP - 20.56% MySQL) with 10 queries |
