Repairing Rockford Fosgate 250a2 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 17th January 2006, 11:28 AM   #1
03Jeep is offline 03Jeep  Canada
Default Repairing Rockford Fosgate 250a2
Hi there, I am new to the forum and am putting together a basic stereo from some old unused parts.
I have a rockford fosgate 250a2 that stopped working a few years ago. It no longer powers up. I remember that I had it mounted under a seat and someone shoved there foot under the seat and kicked the ground out and caused it to short on the 12V.
I was planning on opening it up and checking the capacitors and transistors. If anyone is familiar with where the problem lies, I would greatly appreciate it as my desoldering skills are not that good.
Old 17th January 2006, 07:52 PM   #2
It should have done nothing more than blown the fuse in the power wire feeding the amp. If there were no fuse, it could have burned a trace in the amp.
If you can take some voltage measurements while the amp is connected to a power supply, I'd be willing to try to help.
If you have a digital camera, post or email me a clear photo of the amp.
Old 17th January 2006, 09:05 PM   #3
anatech is offline anatech  Canada
anatech's Avatar
Hi 03Jeep,
If the trigger lead shorted, there is a diode and PNP transistor that may have gone. This amp works by drawing power from the trigger lead into your head unit.
-Chris
Old 18th January 2006, 11:54 AM   #4
It did blow the fuse on the power line. After replacing the fuse and reattaching the ground, the amp never worked.
I can measure some voltages when hooked up to a power supply. At which points would you like me to measure.
I have attached the pics of the amp. One of the front side, and one of the back side.
There is one capacitor missing when I took the pics. I thought it was bad but turned out to be fine. The burn marks on the board are from removing it, it cleaned up fine. I only had a super fat tip when I was desoldering it.
Let me know if you want bigger pics of the amp.
Old 18th January 2006, 11:54 AM   #5
pic 2
Old 18th January 2006, 12:11 PM   #6
anatech's Avatar
Hi 03Jeep,
Please measure the resistance between the battery supply wire and the trigger wire (to the radio).
-Chris
Old 18th January 2006, 02:02 PM   #7
Measure the resistance points A-B and D-E (amp not connected to any source of power). If you get something greater than ~1meg ohms, power the amp up through a 5 amp fuse (nothing larger). Measure the DC voltage at all points in the photo and post the results. The black laed will remain on the ground terminal of the amp for all measurements. Also post the voltage on the remote and B+ inputs (again, black lead on the ground terminal).
Rockford 250a2 Won't turn on stusigpi Car Audio 15 12th May 2010 07:42 AM
Worth repairing a Rockford Fosgate Punch 60.2? wpc Car Audio 14 1st July 2009 06:25 PM
rockford fosgate 550x mike49504 Car Audio 21 6th December 2008 10:26 PM
Rockford Fosgate 325.1 phreaktor Swap Meet 1 28th February 2008 11:54 PM
New Rockford Fosgate amp. $50.00 NerdMike Swap Meet 0 4th March 2005 11:57 PM
Copyright 1999-2017 diyAudio
