speaker box design physics question
Old 18th November 2005, 12:10 PM   #1
priscared is offline priscared  Australia
Send a message via MSN to priscared
Default speaker box design physics question
Hey all,
i was just building my speaker box, (See attached image) i stumbled a across a problem, see the ports where the wrong diameter. so heres the question
If the port was meant to be 7.5cm diameter and 27.5cm long, and i have 8.5cm diameter pipe, how long should the pipe be to be equivalent?
as in the relationshipt between diameter, wavelength and length of the pipe.
i thought i should make it shorter, so i tried that, works OK. But id like it to be better.
thanks all again
daniel
Old 18th November 2005, 01:11 PM   #2
R.I.P.
as the port is bigger in crossectional area it needs to be longer.
Its a square relationship, doubling the diameter of a port means
its length needs to be four times as long for the same frequency.
Which gives an answer of 35cm long.
/Sreten.
Old 18th November 2005, 02:36 PM   #3
Default thanks
thanks man , cheers, now i have to put a right angle in the pipe so it'll fit!
daniel
Old 18th November 2005, 05:02 PM   #4
R.I.P.
don't go the right angle route - it won't work well.
Line the current shortened port with say a stiffish foam to reduce
the effective diameter to nearer say 6.5cm, length then = 21cm.
/sreten.
Old 19th November 2005, 12:07 AM   #5
Default thanks
yeah i was originally goin to use smaller pipe, 6.5cm, dam it lol. But yeah i think ill have to go the right angle way cause i can use foam without it looking shocking
speaker box design physics questionHide this!Advertise here!
Question on physics :) sss The Lounge 51 16th May 2006 03:46 AM
question about speaker box design jaygeorge1979 Multi-Way 7 12th January 2006 03:33 AM
Physics question! Nappylady Multi-Way 3 13th May 2005 02:29 AM
Physics Experiment - building a speaker JasonDelta Multi-Way 2 8th February 2004 01:31 PM
Speaker Design Question r.mcnamara Multi-Way 7 9th December 2002 12:26 AM
