car preamp with artificial earth(ESP)
Old 7th November 2005, 03:09 PM   #21
TO-3 is offline TO-3  Peru
TO-3's Avatar
Send a message via Yahoo to TO-3
Originally posted by sagarverma
will try out ad's whenever i find time to go to the elect. market.r they really worth so much money?how would u rate the performance difference vis-a-vis opa?(u have used both)
They are marketed as precision opamps for very high accuracy analog signals. I think they have a more dynamic sound. They bass is not as pronouced but I think they sound better in mid to high frequencies.
Also, what voltage rails do you have on you OPAs. I usually modify my amps to have +/-18V rails instead of the common +/-15V. That also helps with dynamics.
Check out Tube Driver BLUE products at: www.tubedriver.com
Old 8th November 2005, 04:57 AM   #22
sagarverma is offline sagarverma  India
sagarverma's Avatar
oops!mine are lowly + - 12v
no problem as my transformer is + -20v dc and regulated down to this level.regulating it to + -15v is better for better sound
will try it too.thanks again
Old 8th November 2005, 04:58 PM   #23
TO-3's Avatar
This is usually because the main amp is a transistor stage. As you know, transistors are not that linear so by using an opamp you want to swing your signal(voltage) as much as you can to decrease the amount of transistor gain needed in the main amplification stage.
Old 8th November 2005, 05:31 PM   #24
sagarverma's Avatar
well i tried out + - 15v suggested but i didnt notice a drastic change(as was with opa's).althogh there was a marked and noticiable improvement(fullness to music;i suppose i making myself clear) in the music,it was not as dramatic as opa
but definately it is better.any other mod for improvement.
KARIZMA-JET SET GO...........
car preamp with artificial earth(ESP)Hide this!Advertise here!
Artificial floating ground mhennessy Solid State 10 24th January 2015 09:58 PM
Hi All in the EARTH stoN_Cold Car Audio 0 30th December 2006 06:29 PM
Earth again Pbassred Solid State 20 10th July 2005 08:44 AM
Artificial Harmonics guitargully Instruments and Amps 1 15th April 2004 07:53 AM
Should I come down to Earth ? Prof Chip Amps 19 12th June 2003 03:05 PM
