car preamp with artificial earth(ESP) - Page 2 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 2nd November 2005, 04:11 PM   #11
TO-3 is offline TO-3  Peru
TO-3's Avatar
Send a message via Yahoo to TO-3
The reason for using a 1/3 octave eq is to attenuate or boost a particular frequency. The parametric eq usually can be configured for the particular freqs you wish to "enhance". Also with the parametric eq, usually you can adjust the Q to be very wide or very narrow.
Never heard the term "simulated inductor" but since a cap is theoretically the opposite of a capacitor, you attenuate the higher frequencies to ground via a cap instead of placing a choke in-line. Either way, a cap or inductor will add a phase-shift to your circuit.
Originally posted by sagarverma
hi to3
see this.is it worth??
http://www.sound.westhost.com/project28.htm
know anything more(practical) bout simulated inductors.i read in details bout them in my 2nd year(final year elect. n comm. engg.).
but that was all theory with derivations etc.i need the practical day to day usage and performance info.any idea or link?
i didnt understand parametric equaliser.parametric amp was in syllabus too but i never bothered to read it then.any info bout it too.
see it if any improvements possible.
advise::
in your xover,r the opamps operating at unity gain????if its that then forget bout changing the ics bec NO IMPROVEMENT will b there.if the ics have gain,only then change.
calculations
::::quads:unit price=Rs350 approx.for 15 its approx Rs5000=price of a good sony amp.but here,quads will cost 1/5 or less of what u pay.dunno y but its a pleasant reality
Check out Tube Driver BLUE products at: www.tubedriver.com
Old 2nd November 2005, 04:47 PM   #12
sagarverma's Avatar
i/p is from sony discman which has rather suppressed bass,(pleasant for ears but not speakers)
i suppose parametric is way to go(as u sayin)
will complete it surely and will post accordingly
Old 5th November 2005, 04:53 PM   #13
sagarverma's Avatar
done it
beautiful opamps.looks as well as performance.so quite,clear,magic!!
parametric also done.used freq from 35-150(two controls for better control),150-550hz(one control).result::::even that weak sony sounds blasting
thanks for all help.
******got them cheap(as compared to what u pay),Rs30 per unit(dual).got ten units..i dunno y but its good$1=Rs45.)
Old 6th November 2005, 12:01 AM   #14
TO-3's Avatar
done it
Did you go with the OPA's? They definately add that low-end that seems to get all muddied in the TL072s.
POST PICS. I want to see naked amplifiers!!!!
Old 6th November 2005, 02:22 AM   #15
sagarverma's Avatar
obviously opa!!
great peices.
ic bases.with wonder chips in them.
pic resolution too low bec had to use windows to click pic.(software expired).pcb placed on print out of the pcb layout.
will post high reso asap.
Old 6th November 2005, 02:27 AM   #16
sagarverma's Avatar
and the rear.
artifical earth not used although provision on pcb(designed by me)
Old 6th November 2005, 10:55 PM   #17
TO-3's Avatar
Looks good!!
For fun, you should get a couple AD823s and find out how they sound against the OPAs. Look at the data sheets and check out the specifications.
Old 7th November 2005, 02:38 AM   #18
sagarverma's Avatar
hey
the improvement in sound clarity has been great.the sound preamplification has more clarity and richer details to it that were surely lacking in 072's.
result is that the bases are more clear(withou para eq.).on conecting para eq. also,the result is simply awesome.heavy bass (thrrrrrrrrrrrr thrrrrrrrrrrr sound) o/p .the system will be integrated soon in my car.
will try out ad's also as u saying,but i dont think the difference will b much noticiable(opa is a gem!).
how bout your mod drive of 1/3 octave?
Old 7th November 2005, 03:57 AM   #19
TO-3's Avatar
You might be suprised again.
My project has been on hold for a couple years. I modded all of my Tube Driver stuff with the AD823s. I have the Phase Audio crossover and that had 22 ops to replace. That dented my wallet. But for right now, I don't have a good car and any stereo that I could put in it would only make my car cost more. I have plenty of equipment, but nowhere to put them.
Old 7th November 2005, 05:27 AM   #20
sagarverma's Avatar
will try out ad's whenever i find time to go to the elect. market.r they really worth so much money?how would u rate the performance difference vis-a-vis opa?(u have used both)
Artificial floating ground mhennessy Solid State 10 24th January 2015 08:58 PM
Hi All in the EARTH stoN_Cold Car Audio 0 30th December 2006 05:29 PM
Earth again Pbassred Solid State 20 10th July 2005 07:44 AM
Artificial Harmonics guitargully Instruments and Amps 1 15th April 2004 06:53 AM
Should I come down to Earth ? Prof Chip Amps 19 12th June 2003 02:05 PM
Copyright 1999-2017 diyAudio
