Hi People,
I have never attempted to repair something like this but I would love to get it going.... One of the IRFZ42's on one side has melted. The other side of the amp is fine and they are completely separate (practically dual mono). What I plan to do is get one of these: http://cgi.ebay.com/ws/eBayISAPI.dll...tem=7523201348 and....
Obviously I can use a multimeter etc so any advice? or better ideas or ways of testing it? |
#2 |
I assume that this MOSFET is part of the power supply section so I dont need to match it or anything?
#3 |
Good luck on this one.
I can see various capacitors screaming to be replaced and I wouldn't be surprised you'll find many bad solderings inside as well. /Hugo
#4 | |
![]() Its an Alpine Juba (very rare/expensive) and has Nichicon and Elna audio capacitors
#5 |
Another pic for good measure.
#6 |
I can't and won't comment on the qualities of the amp, but even a Rolls needs service.
![]() Look for caps where the plastic has shrunk from the heat. Take them out and measure them. Why good luck? It looks fairly damaged although cleaning will reduce the ugly sight. Also, without schematic or experience you're on your own in this rats nest. Anyway, aren’t we fearless amplifier builders? /Hugo
#7 | ||
#8 |
strange .
only one blown check em all! and if u power the amp use some precautions like smaller fuse so it wont blow again .
if you are not living on the edge you are taking too much space
#9 |
i know it off topic, but geez, i'm glad my blown alpine dont look like that!
how can you even begin to decide where to begin? but more of a chalenge, how get to the parts in question? |
#10 | ||
| Commercial (Alpine PDX) Class D Failure Pics and Question about IR2010s | CBRworm | Class D | 5 | 1st August 2007 05:18 AM |
| Help needed with Alpine Changer installation | arcosmo | Car Audio | 2 | 17th September 2005 01:15 AM |
| Any advice on replacing SMD Opamps | PHilgeman | Parts | 5 | 1st April 2004 01:34 PM |
| Need advice on replacing caps in amp P/S | cdwitmer | Solid State | 18 | 18th April 2003 10:00 PM |
| Page generated in 0.10010 seconds (83.86% PHP - 16.14% MySQL) with 11 queries |
