Need help choosing subs & amps from the experts - Page 2 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 11th May 2006, 01:07 PM   #11
beppe61 is offline beppe61  Italy
Originally posted by richie00boy
Yes if it can do 10A with 4R load then it will be able to do the same current with heavier load.
But bear in mind that keeping current the same and halving load impedance means that the output power is also halved, just that the required voltage swing is reduced to 0.707x that of the lighter load.
So if voltage swing is to be maintained the supply must be capable of supplying double the current when confronted with half the load impedance.
If it can do this then the output power will also double.
Also to take into account is to what extent can big load increases can be tolerated and how long the power supply can sustain increased demands, which is what your proposed peak current capacity is all about.
But it can be confusing as a big peak capacity does not guarantee a decent steady-state capacity.
Thank you very much indeed again Sir.
Maybe you can think that I am quite obsessed by this thing of the current available from an amp, but my very limited and humble experience tells me that the final sound, when the speakers are driven by a so-called high current amp, has a remarkable authority. Very very nice indeed.
Thank you very much again.
Kind regards,
beppe
Old 11th May 2006, 01:52 PM   #12
Did it Himself
richie00boy's Avatar
No problem Beppe. There is nothing wrong in doing research to verify your own experiences.
In fact, although some people have told you to change drive unit in your speakers, the fact that you have achieved your perfect sound with these speakers when used with a specific amp says to me that you do not need to touch your speakers. Rather you are correct in your quest to search for the right amp.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 11th May 2006, 01:56 PM   #13
No problem Beppe.
Dear Sir,
I would like to thank you for the umpteenth time for your generous, friendly and extremely valuable advice.
Kind regards,
beppe
QSC Amps, subs... danielm Swap Meet 2 12th September 2009 01:11 AM
Choosing from the current crop of t-amps on ebay? den_hr Class D 2 31st May 2009 01:52 PM
Choosing Amps for a 5 Way Active Horn System KCCT82 Pass Labs 32 26th April 2009 12:21 AM
dj amps and car subs ricsta_supra Subwoofers 0 8th June 2004 03:26 AM
Basic question about choosing op amps leadbelly Solid State 1 18th February 2004 08:21 PM
Copyright 1999-2017 diyAudio
