Finished Car Amplifier schematic + PCB based on Kenwood KAC-716
Old 20th July 2005, 03:32 PM   #31
N-Channel is offline N-Channel  United States
N-Channel's Avatar
Send a message via AIM to N-Channel
Default Re: Source of Toroid Cores
Originally posted by cfog88
Hi!
I have seen quite a few references to winding a ferrite core, but haven't yet managed to find a good source for ferrite cores. Where did you get yours?
Thanks,
Chjris
Chris,
Try Amidon Incorporated out of California. For power conversion, they stock ferrite toroid cores in the #77 material that can handle up to 1.5kW at 40kHz! For energy storage (as in the output inductor in an SMPS), they stock powdered-iron toroid cores in the #26 material up to 5.200" (O.D.)!
Their entire catalogue can be downloaded from their website, at:
www.amidoncorp.com
I have made many SMPSs with toroids from Amidon for both the power transformer and the output inductor, with great results.
Steve
Old 21st July 2005, 05:01 AM   #32
leinahtan is offline leinahtan  Philippines
Send a message via Yahoo to leinahtan
Hi, RISTO80....i just want to know the switching frequency of your smps via the schematic diagram of KAC-716 scheme......i am kinda confused about it..
Give me such thing and i'll give back to you......
Old 21st July 2005, 05:38 AM   #33
Default Another SMPS schematic
Hello everyone especially to RISTO80.....i have posted here the schematic diagram below......of JBL-50 SMPS and i would like to know if you have a way to design the pcb layout like the one you posted upon the modification of KAC-716 SMPS.....i think its the same but different in mosfet used...Kindly look it up for our references... thank you
Old 25th July 2005, 06:46 PM   #34
arasuk is offline arasuk  India
Send a message via ICQ to arasuk Send a message via AIM to arasuk
Hi, RISTO80,
Have you finished this project, can you give more details on the pre amp and amp, Whats the turns for the ferrite .
Arasuk
Old 26th July 2005, 06:32 AM   #35
MosfetBoy is offline MosfetBoy  South Africa
I'm surprised to see so many amps with no regulation on the switchmode.
If you look at the Elliot Sound Products web page, their switchmode is regulated ( can be seen at http://sound.westhost.com/project89.htm#fig9)
The only drawback with this one is that there is no temperature shutdown on their design, which i think i'd want if it was in a car.
John
Old 19th October 2005, 08:53 AM   #36
aman is offline aman  India
aman's Avatar
Default help!!!
hi RISTO80
I built the smps of kenwood amp as per ur schematic and layout .I used a toroidal stripped off from an old car amplifier (35-0-35, primary 6+6 and secondary 12+12) though the output voltage is ok but as soon as i connect the load (amplifier) the bridge rectifier diodes 35Amp/400volt start becoming hot. I didnt use the remote transistor c925 and a1534 as i have connected the +12v directly to the ic. I dont have the scope to determine the frequency wave.What could be the problem.
regards
Old 19th October 2005, 11:14 PM   #37
Risto80 is offline Risto80  Macedonia
Banned
Send a message via AIM to Risto80 Send a message via MSN to Risto80 Send a message via Yahoo to Risto80
Talking Hi
Hello to everybody
I am glad to see that the interest of this project is very big.
Firs of all now days my project is finish I now days I am testing with 12 sub speaker and it works very good. I will put digital and more clearance picture when I find data cable for Minolta “Damage X”.
I will answer for some questions:
The switching frequency is determined with RT-resistor 16k and CT-capacitor 1nf witch are connected with pin 6 and pin 5. The approach is done with equation Fclk= 1/(RTxCT). So RT=16k and CT=0.001uf and Fclk=62.5Khz.You can read more from valveaudio site.
I used standard ferrite core with primary turns 2x4 turns and secondary 2x12 turns and I have +/-37 volts.
The schematic of JBL-50 SMPS will not work wit amp of that design. Better is to build the smps of Kenwood because is more powerful and better designed.
About the regulation of SMPS. Most trade marks like Kenwood used non regulation system because is more powerful and the fets is not so hot.
And for aman. The toroid and winding is good. Used the transistors for remote control don’t connected direct to +12 volts to pin of TL494.
For bridge rectifier you used regular of fast recovery bridge rectifier. You must used fast bridge rectifier the regular one will always burn.
Also check the wirings from bridge and the PCB because the PCB is not design for bridge rectifier. Check if you connected correctly.
By for know and if you have any questions put them on this site.
Old 21st October 2005, 06:18 AM   #38
aman's Avatar
Wink smps working
Hi Risto80
I made the smps work.I used the fast diode now MUR22 and correctrly inserted the 1000p in the output of the toroidal which i wrongly connected before. I used it with my existing amplifier and it sounded awesome,smps is really powerful and the mosfets and the toroidal are cool.
However there is something wrong in the pcb tracks for the diodes MUR22 i.e the secondary of the toroidal should go to the center pins of the diodes and the. so i also corrected the tracks on my pcb. I also used another toroidal with more secondary and it gave me 56-0-56 volts.I m thinking of using it for an amp using 2* a1943/c5200 working on 56-0-56 for which i have only made the pcb and not filled it with components yet. What are ur suggestions??
regards
Aman
Old 21st October 2005, 11:34 AM   #39
Default SMPS!!!!
Hi Aman
Great to hear that your smps works , which amp did you check with, and where could you get the toroids,
whats the primary & secondary turns & whats the wire guage.
Arasuk
Old 21st October 2005, 12:24 PM   #40
aman's Avatar
Default smps checked
Hi Arasuk
I tested the smps with a car amp using tip2955/3055 in the output. I first disconnected its own 35-0-35 from its smps supply ,just disconnected the jumper to the amp section. I got the toroidal core from the lajpat rai market in delhi.The shop has got every king of ferrite core.I bought 3-4 pieces of the cores of 2cm and 3cm inner diameter.There are 6+6 turns in the primary and 12+12 in the secondary.I dont remember the wire guage but i used double wires of 20guage i think for the primary and single wire of 19guage for the secondary. sorry......i am not sure abt the wire guage. But if u wanna really wanna know the guage i will tell u.
regards
Aman
Aman_4g@yahoo.com
Finished Car Amplifier schematic + PCB based on Kenwood KAC-716Hide this!Advertise here!
PGA2310 based preamp finished bostjancek Chip Amps 24 19th July 2010 08:59 PM
Finished amp (based on TA2024) maurycy Class D 0 21st January 2009 01:24 PM
ThermalTrak based Amplifier finished Arius Solid State 23 23rd April 2008 11:24 PM
Schematic Kenwood KHA-50 schnullimaus Solid State 1 8th July 2006 10:29 AM
