Go Back   Home > Forums > General Interest > Car Audio
Old 26th March 2009, 03:37 PM   #111
AUDISOUL's Avatar
Default MY SMPS PCB
Hi All,
My SMPS pcb at here:
http://www.diyaudio.com/forums/showt...99#post1785299
Old 9th April 2009, 07:02 AM   #112
AUDISOUL's Avatar
Hi All,
This all the designs (Post #616 and before) are design by my best Friend, But he dont want to giving this designs to all the guys so sorry and I cant help any body.dont mail me for the designs.He is hurt than I have stop to put his designs here.
Old 6th May 2009, 02:03 PM   #113
anselhu is offline anselhu  China
Send a message via MSN to anselhu
Smile Car Amplifiers Class D
Who-to-use, high-power Class D schematic diagram of the hair to think about points. Thank you!
Old 2nd July 2009, 03:59 AM   #114
hi,
can i replace fmu22r and fmu22s with FEP16GT? One positive CT and one negative CT. I'm still learning and I don't know what to look for but I need to find a local replacement. Any other common replacements?
Old 3rd July 2009, 03:47 AM   #115
N-Channel's Avatar
Send a message via AIM to N-Channel
Shouldn't be a problem, if you know voltage & current ratings of the diodes you're putting in. An easier approach: Sample some ultra-fast diodes from On Semiconductor. Specifically: MUR1620CT (+) and MUR1620CTR (-). Rated at 200PIV, and 8A per leg.
Old 5th July 2009, 09:44 AM   #116
Thank you! I can get that at a shop here
I took the liberty to attempt to test just the amplifier board today by hooking it up to a 30 volt 5 amp transformer i had around. The signal was a mono 3.5 jack i hooked up to a cd player. All I got was a loud buzzing... I unplugged it after a bit of smoke started coming from the board. All of the transistors stayed cool. I used a 470 ohm trimpot instead of the 330 one called for. As well i used a 2.3k resistor where it called for a 2k2 resistor.
Are my lack luster results due to using a 30-0-30 transformer and a cd player? I may have hooked up the transformer backwards, ie 40+ to 30- and 40- to 30+ as it was a surplus buy and had no markings. If the problem is the board itself I've got a lot of extra parts and I think I'll tear it down and start over. Maybe even try to be a bit more attentive this time...
Old 6th July 2009, 02:28 AM   #117
N-Channel's Avatar
Lemon,
First, start out by taking raw AC measurements across all the transformer secondaries before you connect them (assumed thru a rectifier & filter cap) to anything! Remember, if you read 30VAC, it's really peaking out at 42.42V, so you will wan to t de-rate your amp's voltage operating points, if possible.
Second, once you have sorted out all the secondaries, connect your rectifier bridge and two caps and measure the (+) & (-) voltages. Once you're satisfied you have good readings, correct any of the damage you mave done to the main amp board, and try it again.
Steve
Old 9th July 2009, 10:28 PM   #118
The bridge rectifier is putting out 36 volts dc. Shouldn't it be 60ish volts between the positive and negative wire? Anyways, I have one 3300 uF capacitor between positive and ground and negative and ground. I tried it again after cleaning up alot of stuff. I did it without a speaker and it stayed cool so I hooked it up to a speaker without a signal coming in and pooff the speaker went up in smoke. It was a free two way speaker with 120 watts max power, but the problem is that there was a hum while it was hooked up... and that it fried...
Why would the amp be putting out so much power with no signal? :| so I'm guessing that means transistors are fried. How can I check this?
Old 21st July 2009, 01:57 PM   #119
Im slowly working through my errors now. This is my first audio amplifier project, I'm a first year mechanical engineering student and it's quite humbling to learn how little you know!
Will I be able to test this amplifier on my 30 volt CT transformer? Which I now realize is putting out +/-18V DC at 5A max... I hope its sufficient because I'd like to test at a low voltage at first.
Thanks for the help! I'm sure a lot of you hate teenagers coming here requesting how to make a subwoofer amplifier but I'm trying to learn
Old 21st July 2009, 10:46 PM   #120
luka is offline luka  Slovenia
luka's Avatar
Send a message via Skype™ to luka
If you set your feedback to lower voltage, you will have lower voltage on output
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
PGA2310 based preamp finished bostjancek Chip Amps 24 19th July 2010 08:59 PM
Finished amp (based on TA2024) maurycy Class D 0 21st January 2009 01:24 PM
ThermalTrak based Amplifier finished Arius Solid State 23 23rd April 2008 11:24 PM
Schematic Kenwood KHA-50 schnullimaus Solid State 1 8th July 2006 10:29 AM
Copyright ©1999-2013 diyAudio
