Go Back   Home > Forums > General Interest > Car Audio
Old 6th April 2005, 09:35 PM   #1
nicad2 is offline nicad2  United States
Smile PPI Amplifier Restoration: Power Wires
Hello All,
I have been having alot of fun recently working on a project to restore some old Precision Power (PPI) Art Series amplifiers. I am talking about the ones with extruded aluminum fins, not the ones with triangular and circular heatsinks. As you may know these amps have hardwired 10-12ga power wires. Since my particular amps have been installed numerous times, their power wires have gotten quite short.
I would like to replace these short power wires with some new high-quality ones, but everything I find has one or more of the following problems.
1) The color doesn't match. Usually the reds wires are translucent and/or a completely different shade.
2) The wire jacket is so thick, that I won't be able to fit them through the openings in the amp. I'm guessing these huge "looking" wires sell well.
3) The strand count is so low that the wires are not very flexible.
4) The conductors are not corrosion resistant.
Does anyone have recommendations of brands or sources for high-quality power wires similar to what came with these amps originally?
Thanks!
I tried attaching a picture of what the wires should look like, its not working.
Old 7th April 2005, 05:45 PM   #2
TO-3 is offline TO-3  Peru
TO-3's Avatar
Send a message via Yahoo to TO-3
Default Re: PPI Amplifier Restoration: Power Wires
Originally posted by nicad2
Hello All,
Thanks!
1) Why do you need a red and black cable? The conductivity is not dependent on the color of the color of the insulation.
2) Drill
3) Get wires with a larger thread count.
4) HUH?!?!?!
If you think those cables were high-quality, maybe you should find someone else to fix it.
Check out Tube Driver BLUE products at: www.tubedriver.com
Old 7th April 2005, 07:21 PM   #3
Default Re: Re: PPI Amplifier Restoration: Power Wires
I am aware of the many options that would make the amp functionally equivalent to its original condition.
Since I am restoring this amplifier, my objective is to also make it cosmetically equivalent.
Thanks, my circuits professor didn't cover that .
2) Drill
This is an option, but would require a larger grommet and would not be cosmetically equivalent. I prefer to avoid this if possible.
Yes, can you recommend any good sources?
4) HUH?!?!?!
I found some wires that met the other requirements, but were very prone to corrosion (high oxygen content copper?).
Old 7th April 2005, 09:45 PM   #4
TO-3's Avatar
Radio shack.
When I worked at PPI, we just used whatever wire we had in stock to replace those cables. It was a stupid idea to begin with(hardwiring power cables to the board) but I have always belived in functionality over asthetics(except when I built the PPI2500 F-1's), that had to be both.
Old 7th April 2005, 10:03 PM   #5
It looks like you are looking through the car stereo section at a local store. You do not need/want special "car stereo" power wires! I'd go to a generic electronics place/surplus shop and look at all their wires. You might also have some luck looking in the electrical section of an Autozone (the electrical section, not the stereo section), or at a place (Home Depot, etc) that sells wiring meant for AC power.
Old 8th April 2005, 06:37 AM   #6
Yeah, I checked several local car audio shops. They didn't have anything smaller than 8ga. The retail shops (Fry's,BB,CC) had 10ga wire, but you had to buy it in a kit ($50+). Home Depot/Lowes had some appropriately sized wire, but it flunks the high strand count and color match requirements. The red was pretty close to pink!
I haven't tried any autoparts or surplus stores yet. Thanks for the suggestion, I'll give it a shot.
I just found these. They look pretty good, but they don't list the diameter. I'll have to send them a note to see.
www.robotcombat.com/store_wire.html
Old 30th April 2006, 06:46 PM   #7
creyc is offline creyc  United States
I've used those Deans "Wet Noodle" wire listed on that page for other projects (like RC cars) and it is great stuff, and VERY flexible! I imagine that would suit you well, it was very high quality wire.
Old 1st May 2006, 08:25 PM   #8
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Oxygen content in copper is a wire marketing fairy tale.
Better handling of corrosion in OFC wire is another marketing tale, but much more stupid than the previous one. First, changes in copper purity within the 99% range don't have any effect on corrosion. Second, those thin-strand "car-audio" power wires get corroded much easier than standard thick stranded wire, and the amount of damage done by corrosion is much more important. That's because the copper surface exposed to air and humidity is at least an order of magnitude higher than in thick-stranded wires, which are far more reliable.
I use to feel like the small child in The Emperor's New Clothes tale
Old 8th May 2006, 07:59 PM   #9
I ended up using power wires by "Amp King". The color, thickness and flexibility are all inline with what I was looking for. The 8ga size required enlarging the power cable hole, but the 10ga did not. They look great and the price is reasonable.
old school usa - 100 with all wires coming out the amplifier instead of terminals smartyart Car Audio 17 11th November 2009 02:37 AM
Can you help me choose capacitors for my amplifier restoration project? Kuja Solid State 16 12th March 2007 10:46 AM
Solderless gainlone amplifier? (crimps, wires and terminal blocks) ash_dac Chip Amps 6 28th July 2006 02:53 PM
Conductors (I.C.'s, RCAs, internal wires, speaker wires) bigphil Parts 1 25th November 2005 06:47 PM
Power Supply Secondary wires Mermprin Parts 4 20th July 2004 09:32 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
