Go Back   Home > Forums > General Interest > Car Audio
Old 7th December 2004, 06:49 AM   #1
Wink irritating sounds from speaker
hi guys, think you might help me with this.....i have a sound set-up, its working fine but i hear ticking sounds from my speakers whenever i turn on my flasher or buzzing sound when i turn on my aircon.
thanks!!
Old 7th December 2004, 05:07 PM   #2
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
we can only guess if you don't tell us what equipment are you using. how many amps do you have? how many speakers? any signal processors? how is it wired? who did the install?
Old 7th December 2004, 09:08 PM   #3
Puggie is offline Puggie  United Kingdom
sounds like a dodgy earth.
Check all your earths are good and onto bare metal.
Old 8th December 2004, 07:49 AM   #4
pioneer hu
alpine amplifier (4 channels) 100watts rms (NEW)
12" targa sub in a sealed box, volume is 1.5 cu.m. ( can i add a port in this box???)
front speakers = 6.5" pioneer (2way)
rear speakers = 6.5" pioneer (2way)
wiring= channles 1 and 2 connected to the rear speakers, channel 3 & 4 to the subs (bridged)
i did the wiring since ive done it before and it did fine...old amp btw is a 2 channel hotshots (american acoustics) with 300 watts rms, MOSFET, 2 OHM stable
Old 8th December 2004, 01:59 PM   #5
jackinnj's Avatar
put a choke (a few hundred microhenries) on the power inputs to the Alpine amp/tuner and the sub-amp. You can make a suitable choke from one of the torroids in the input section of a junked AT power supply.
Old 12th December 2004, 12:44 PM   #6
your interconnects might be damaged check them. I had the same experience before but when I swapped cables, the problem disappeared.
Old 12th December 2004, 05:37 PM   #7
Send a message via AIM to minitruck_freq
it may be a grounding issue. check all your grounds. make sure they are solid and grounded to bare metal. and check all wiring while you are at it.
Old 19th August 2007, 12:01 PM   #8
longthrow's Avatar
Send a message via MSN to longthrow Send a message via Yahoo to longthrow
probably the way you make connections on the ground..
a few more chokes can help..
H V E Audio
Old 20th August 2007, 12:16 AM   #9
ppia600 is offline ppia600  United States
Take an ohm meter and read the resistance from the ground side of the rca connectors on the back of the radio to the body of the radio. If it isn't a direct connection to chassis ground of the radio, that is your problem.
Speaker sounds blown...but isn't bereanbill Tubes / Valves 16 17th June 2009 04:29 PM
Speaker problem - sounds muffled wixy Full Range 6 5th September 2006 10:59 PM
Irritating buzz... where is it comming from??? Devius Chip Amps 82 7th January 2006 07:49 PM
My NSB sewer speaker sounds like a 2" bose MPM Full Range 23 6th January 2005 05:36 PM
Help!! Irritating sound of my GainKlone overmind Chip Amps 37 8th June 2003 12:26 PM
Page generated in 0.08928 seconds (77.26% PHP - 22.74% MySQL) with 10 queries
