#11 |
yes, u r right. its similar to the ON- Pin of the FT326.
#12 |
hi Magna,
Based on the schematic that you had posted using TDA1562, I had managed to build it and is working fine. Thanks. Will post some pictures of it later. So did you manage to built the FT326? |
#13 |
#14 |
Good Amp can I use It for Sub woofer?
#15 |
Bandwidth depends on choice of lift capacitors. The bigger the lower in frequency it can go. So can be perfectly suited for a sub.
| FS Alnico Philips AD3800M AD3800AM and Philips transformers | guglielmope | Swap Meet | 8 | 10th January 2011 12:28 PM |
| Are my two TDA1562 destroyed?? | newbadboy | Chip Amps | 2 | 10th June 2009 01:13 PM |
| philips cd 880 philips cd880 service manual | 0519 | Digital Source | 4 | 28th August 2008 12:43 PM |
| philips cd 304 mk2 | beamnet | Swap Meet | 0 | 24th December 2006 03:36 PM |
| Low Power Output with TDA1562 | pedopapa | Car Audio | 3 | 14th October 2005 02:11 PM |
| Page generated in 0.08236 seconds (65.50% PHP - 34.50% MySQL) with 11 queries |
