problem selecting midbass/sub - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 15th November 2004, 01:40 AM   #1
Theli is offline Theli  Canada
Question problem selecting midbass/sub
Hi all,
I`m trying to decide between 4 speakers:
JL Audio 6W0 (a pair of drivers, each in seperate enclosures)
Adire Extremis6 (a pair of drivers, each in seperate enclosures, but I don't think these are designed for cars)
JL 8W0 (one driver)
Adire Koda8 (one driver)
I`m looking for a bit of lowend to fill out sound, but I don't need to annoy neighbours. I just don't want a sub box sitting in my trunk or between the front and back seats. The drivers would be mounted in custom made boxes in "empty spaces" in the car, such as a door.
The freq. response are similar on all 4, so what would be the next deciding factor? SPL, Max SPL...? I'm running an older Sony Mobile ES 4ch amp , 1 ohm stable, 35x4 or 100x2 @4ohm.
thanks for looking,
Mike
Old 19th November 2004, 01:26 AM   #2
I run 8 of the jl`s and they did their job well.
Lost in wonderland..........
now where that rabbit go??
Old 19th November 2004, 02:47 AM   #3
BassAwdyO's Avatar
Send a message via AIM to BassAwdyO
You are using the speakers to extend your bass response? Or are they for midbass and midrange also? The XBL drivers would surely give you better midrange and midbasss (especially extremis). I believe the difference between most car audio and home drivers is the off axis response. If you're only using the speakers to extend bass down low then this is no concern. The dual extremis6's would probably give you the highest output.
The golden rule of DIY:
Build nice, or build twice!
Old 19th November 2004, 03:40 AM   #4
yup, I`m just looking for bass extension, I can't stand having a sub box taking up space in my car
Old 21st November 2004, 03:19 PM   #5
pks71 is offline pks71  Canada
the jl 6w0 are great lil subs but reguire a encloser of .17ft3. If you put them under the seat for lows, that would be great. If you are going to put the woofers in doors you need a woofer thats made for doors(infanite baffle). Jl does make a 6.5 that is made for doors, it looks just like the 6w0 but is for infanate baffle( no enclosure).
Hope this helped
If don't fit modify it!
Old 22nd November 2004, 04:16 AM   #6
Hope this helped
well, they aren't actually going into a door, but would be installed beside the rear seat (2 door car/4 seater). There is a larger space behind the panels where a custom fibreglass box would fit.
Help selecting a DIY amp for... BlizzofOZ Chip Amps 1 30th April 2009 09:38 PM
Help selecting DIY amp for... BlizzofOZ Class D 2 29th April 2009 03:03 PM
Selecting a project Hewie Multi-Way 1 23rd July 2002 11:24 PM
Help selecting an amp FBLEAGH Solid State 1 21st September 2001 05:00 PM
Copyright 1999-2017 diyAudio
