Audiobahn A8002T fan
Old 18th November 2004, 02:22 AM   #11
Regal1 is offline Regal1  United States
Send a message via AIM to Regal1
no, the fan is installed in the factory location, on a sheetmetal mount in the middle of the board, I have removed it and it spins just the same as when mounted. The fan spins fine when hooked up to my power supply, but i haven't yet measured the current draw on it while running.
one of the only things i do not have is a scope, i have a few DMM's and freq generators. Do you think i could measure this with a DMM set to AC voltage?
This is quite perplexing.
(when you place your finger in the middle of the fan motor, it is quite hot, not just from radiant temps in the enclosure)
Old 18th November 2004, 02:28 AM   #12
sdoom is offline sdoom  Germany
Not sure, what are the readings on AC ? Problem is, most DMM īs are only accurate on sinewave , not on square voltage.
Does your DMM have a diode-test function ? You could check the transistor that powers the fan. It is perplexing to have voltage but no spin.........
I assume the old housewife-trick ( hit the damn thing) isnīt gonna work
Old 18th November 2004, 02:31 AM   #13
BTW. Do you have another fan ? Maybe one out of an old computer power supply or a CPU-cooler. Just to really make sure it is NOT the fan. Sorry if I am annoying , but I always doublecheck electronics
Hm, can you follow the lines on the curcuit board ? Whatīs the part number of the transistor ?
Old 18th November 2004, 02:44 AM   #14
i do have a fan that i will check soon.
the transistor's that are in the circuit (not sure if both are in this, the traces are so small, i cant see which does what without removing them.)
Kia 7805A is the larger of the two
the other is listed as:
B631K
Y 407
on the transistor itself.
Old 18th November 2004, 03:00 AM   #15
Ok. Those are the transistors:
KTB631 = 2SB631 . That is a PNP transistor
If you look from the top the pins will be (from left to right)
XXXXX
XX XX
XXXXX <----- Transistor
XXXXX
XXXXX
X X X
X X X
X X X
X X X
X X X
E C B
__________________________________________________ _
KIA7805 = ĩA7805 is a 3pin voltage regulator IC , 5V
front view
XXXXXX
XX XX
XXXXXX
XXXXXX
XXXXXX
X X X
X X X
X X X
X X X
X X X
I G O (input, ground , output)
Old 18th November 2004, 04:11 PM   #16
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
try adding a bypassing cap across the power terminals of the fan. about 100nF-10uF.
Audiobahn A8002T fanHide this!Advertise here!
A8002t help audiobahnkid592 Car Audio 2 12th December 2008 02:14 AM
audiobahn a8002t weird probleme jcl666 Car Audio 1 5th May 2006 02:54 AM
audiobahn A8002T pat99 Car Audio 1 11th January 2006 05:26 PM
Audiobahn A8002T pat99 Car Audio 3 18th December 2005 07:46 PM
powering shiva w/ a8002t 1needforspeed Car Audio 0 13th November 2004 12:32 AM
Copyright ©1999-2017 diyAudio
