car power supply
car power supply
Old 6th November 2004, 09:48 AM   #1
martin88 is offline martin88  United Kingdom
Exclamation car power supply
Hi all
I dont know if this should go here i wana put a pc in my car and wanted to make a power supply that will run off a standered 1v car battery.
Anone know of any websight that have schematics for this or has anyone here done it
thanks in advance
Old 6th November 2004, 01:17 PM   #2
paulb is offline paulb  Canada
Here's one. No idea if it actually works.
http://www.web-ee.com/Schematics/110...e/inverter.htm
Old 6th November 2004, 01:36 PM   #3
DigitalJunkie is offline DigitalJunkie  United States
Send a message via AIM to DigitalJunkie
Heres a link to a linear (sorta inefficient) AT PC PSU I built up..nothing fancy,but it's fairly simple,and uses (for the most part) common parts.
(for ATX add a 3.3V reg,and a constant source of +5V)
http://www.users.qwest.net/~ptaylor/...er_supply.html
and a couple more simple inverter circuits,just for kicks..
http://www.i4at.org/lib2/inverter.htm
http://www.interq.or.jp/japan/se-inoue/e_ckt8.htm
http://www.interq.or.jp/japan/se-inoue/e_ckt30_1.htm
Old 6th November 2004, 02:47 PM   #4
sss is offline sss  Israel
sss's Avatar
Send a message via ICQ to sss
its cheaper to buy a power supply for cars that converts 12v dc to 220v/110v ac
Old 7th November 2004, 01:12 AM   #5
SupraGuy is offline SupraGuy  Canada
Send a message via ICQ to SupraGuy Send a message via Yahoo to SupraGuy
Cheaper, yes, but less efficient.
The only tricky voltages to provide are -5 and -12V. Standard LM7812 and LM7905 ICs will provide a regulated 12V and 5V easily enough. You may need a few of these in parallel in order to provide adequate current, but that's not a big deal. An LM317 could also be used for these, and for the 3.3V supply as well.
Undervoltage protection should be incorporated, in case the battery voltage falls below about 12.5V (Needed to provide 12V from the LM7812) If you prefer other DC-DC circuits can be used which can provide 12V from as little as 5V -- This may be a better idea.
MAXIM IC makes DC-DC converters which can provide the -12 and -5V easily enough. Actually they have standard components to provide all the voltages that you'd need to power a PC from a 5V DC supply of adequate current with excellent efficiency.
Otherwise, you could build your own switchmode supply. You could even respec a standard PC switching supply in the oscillator section to run off of 12-14V at higher current to the transformer. I've also heard of power supplies which can be run from 230VAC, 115VAC, or 12VDC.
There are 10 types of people in the world. Those who understand binary, and those who don't.
car power supplyHide this!Advertise here!
Split Voltage Switching Power Supply for Power Amp vectorplane Swap Meet 2 24th April 2011 12:48 AM
LTspice tool for power amp power supply component evaluation andy_c Software Tools 2 23rd August 2009 06:10 PM
Can i use a computer power supply to power audio amplifiers? destroyer X Solid State 91 25th September 2006 05:36 AM
selling high current power supply for power amps. ericpeters Swap Meet 0 14th January 2005 03:21 PM
heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? jarthel Tubes / Valves 10 21st July 2003 02:30 PM
