Soundstream Reference 405s problem - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 22nd September 2004, 01:22 AM   #1
Zreon is offline Zreon  United States
Send a message via AIM to Zreon Send a message via MSN to Zreon Send a message via Yahoo to Zreon
Unhappy Soundstream Reference 405s problem
My friend just gave me his old Sounstream 405s amp because it had a problem and he didn't feel like trying to fix it so he just bought a new amp. The problem is, everytime it turns on, both fuses blow instantly. I read the manual and it said if this happens, to switch it to high current mode which I did, but the same thing still happens. So I'm just wondering if anyone has had this amp with this problem or another amp with the same problem. If you did, could you give me any suggestions on how to get it working again?
-David
Old 22nd September 2004, 01:38 AM   #2
tenderland's Avatar
Default fried amp
The output xistors are shorted / or the switching power suplply is shorted(drive transitors or dioode bridge) . This is a job for a trusty OHM meter.
Jeff
Old 22nd September 2004, 02:33 AM   #3
Thanks for the quick respone Jeff. I just have a couple of questions. First off, I'm not positive where all of those components are on the amplifier. My dad and me both have experience with electrical components, but we have never worked on a car amplifier. So if you could point out where they are in the picture, that would be very helpful. Also, is there any way to test the output resistors while they are still in the circuit?
Old 23rd September 2004, 02:12 AM   #4
tenderland's Avatar
Default soundstream
Hello
The powerpsupply is on the right .the amp on the left
Do you see the white outlined little boxes? with three leads on each
those are the xistors and diode bridges. Take a ohm meter and ohm
out the leads to each other . look for ones that are completely shorted
(all 3 pins shotred to each other) let me know what you find .
jeff
Old 28th September 2004, 03:46 AM   #5
I just took a ohm meter to all of the xistors and found 3 shorted ones. I am going to take the circuit board off tomorrow and run down to a parts store to see if I can find the 3 I need. The attached picture is where the short circuited ones are. 2 of them are by the high power switch.
-David
Old 28th September 2004, 09:17 AM   #6
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
the three marked with a green thingy?
no, I don't think they are the main power mosfets. I think they are output rectifiers. as the power mosfets are beside the many filter caps.
Old 29th September 2004, 02:25 AM   #7
tenderland's Avatar
Default shorted
Before you "run " down to the parts store check each device out of circuit and confirm it is shorted take youre time when you take the board out . each device has silicone greae on it , take care not to get it all over. also double check the xistors on the left in the amp. ther should be no shorts from one pin to any other.
jeff
Old 27th March 2009, 05:14 AM   #8
i have this same amp and this same problem can someone help me out on how to test these and what reading am i to get?
Old 27th March 2009, 05:34 AM   #9
Check the rectifiers (D3-D8 near the power transformer) and all of the output transistors to see if any are shorted.
You should not read anything near 0 ohms between the legs of any individual transistor. You should not read anything near 0 ohms between the center leg and either out leg of any individual rectifier.
Old 28th March 2009, 09:27 AM   #10
i understand everything except for how to test this specific mosfet/ fet due to the arrows both pointing to the right on BCAE it doesnt show how to check this particular one so if someone can give me the order this one is done in
SoundStream Reference 405S Schematic anyone? kds9591 Car Audio 10 29th February 2016 08:46 AM
Soundstream Reference 604 Herb009 Car Audio 7 9th January 2008 09:52 PM
soundstream reference 604 Bgun Car Audio 9 7th October 2006 05:24 AM
Soundstream Reference 300 Problem notacop Car Audio 12 22nd February 2006 12:24 AM
soundstream reference 405 problem suprmanDL Car Audio 3 21st January 2005 08:46 PM
Copyright 1999-2017 diyAudio
