Noise Supressor - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 8th September 2004, 12:18 PM   #1
Default Noise Supressor
any 1 got any help or a guide on fitting an audio supressor to the bck of the cd player. the intructions on the box arnt very clear atall. its from halfords, 6.99.
it is a saxo so the battery + and the ACC wires have been swaped around.
thanks
Old 9th September 2004, 08:22 AM   #2
Did it Himself
richie00boy's Avatar
If its a coil of wire type then you just connect it in line with the power feed. This will be the wire with the fuse and probably also the thicker wire of the red/yellow choice.
Old 9th September 2004, 12:26 PM   #3
it has a black box, with 2 wires comin outta each side, ground remote, possitive and negative. but am not sure how to connect it up.
any 1 got any guides on it??
thanks
Old 9th September 2004, 12:49 PM   #4
Did it Himself
Dunno then. I've only ever seen ones with 2 wires.
Have you been back to Halfords and asked one of the Ripspeed people there? They are usually very helpful.
Old 9th September 2004, 01:05 PM   #5
johnnyx is offline johnnyx  United Kingdom
It would appear from the description that both positive and negative rails have series inductors. Probably something like;-
Low noise transistor and noise figure Real_Macgyver Solid State 28 27th July 2012 10:42 AM
~AC~ easy line/RF filter + surge supressor schematic wanted bluesmoke Everything Else 2 9th May 2011 07:06 AM
anyone tried this for low noise 5v? mlloyd1 Digital Source 1 25th May 2006 01:06 PM
Noise in DAC Bernhard Digital Source 5 21st April 2004 09:22 PM
Noise in CG chrish Chip Amps 15 4th December 2003 03:58 PM
Copyright 1999-2017 diyAudio
