how do i connect two amps to my one sub
Old 20th August 2004, 05:26 AM   #1
mitchell is offline mitchell  Australia
Default how do i connect two amps to my one sub
i have a sony 250 w amp running a pioneer 700w sub and i want to know if or how i can add another 150 w amp
Old 20th August 2004, 08:41 AM   #2
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
no
Old 20th August 2004, 09:15 AM   #3
sss is offline sss  Israel
sss's Avatar
Send a message via ICQ to sss
i guess u want to connect them in bridge mode ,
if so u need 2 identical amps
Old 20th August 2004, 09:50 AM   #4
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
Assuming they are either single channel amps (which are usually internally bridged anyway, so prolly not) or a dual voice coil sub.
Old 20th August 2004, 03:03 PM   #5
Paradise_Ice is offline Paradise_Ice  United States
Paradise_Ice's Avatar
If your Subwoofer is not a dual coil type, then i would not attempt this.
Just be happy with what you have, more power always means more heat, The Pioneer subwoofers have nice voice coil formers but they can only take a certian amount of heat before failure.
one other thing is, your Pioneer has a Maximium power rating of 800 watts, this is a dynamic rating and not a RMS rating, if you attempt to apply this much power too your subwoofer you will reduce its life span, am talking days even hours, oppsssseee!
Old 21st August 2004, 12:45 AM   #6
DilutedImage is offline DilutedImage  United States
Originally posted by theAnonymous1
no
I couldn't have said it better .. .
Old 21st August 2004, 02:06 AM   #7
Default thanx for your help
thanx for your help
Old 25th August 2004, 04:35 AM   #8
labjr is offline labjr  United States
Not exactly !! A mono amp is just that. It's not internally bridged.
Old 25th August 2004, 05:37 AM   #9
bigmike216 is offline bigmike216  Canada
Not always. Take a look at the of the lower prices, high power amps.. most of them are internaly bridged.
how do i connect two amps to my one subHide this!Advertise here!
How connect the Gnd. samsagaz Chip Amps 50 19th May 2008 06:09 AM
How to connect 2 amps to 1 pair speakers? ransom peek Multi-Way 1 10th October 2006 08:56 PM
connect a sub to amp JSD777 Chip Amps 8 26th October 2005 05:16 PM
how to connect 2 amps to one woofer rulezzz Chip Amps 4 4th January 2004 08:15 PM
Active cross-over, solid state amps connect directly to tweeter? Drew Eckhardt Multi-Way 14 24th August 2003 07:36 AM
Copyright ©1999-2017 diyAudio
