Go Back   Home > Forums > General Interest > Car Audio
Old 17th August 2004, 03:16 AM   #1
Question port location?
Does a port have to be in the front of the box with the woofer, or can it be mounted anywhere on the box? I want to mount my port
which is 2in diameter 9in long in the side of my wedge box im almost done building. Will it work? I currently had it planned out to be tuned to 32hz with that port on the side, but now i dont know if it will work that way. I havnt cut the whole yet so i can still use as a sealed box. Another option is to tune at 37hz, 2in diam. 7in long and beable to mount it in the front. Im really aiming for 32hz. Thx. Btw, the box is for 2 subs(10's), in seperated chambers, one being ported, other one sealed( for now atleast).
Old 17th August 2004, 12:41 PM   #2
black00 is offline black00  United States
Send a message via AIM to black00
you should contact 95honda about this...he'll help you through every step of the way.
Old 17th August 2004, 04:50 PM   #3
theAnonymous1's Avatar
Generally you want to keep the port as close to the speaker as possible, but because your box isn't "huge" you can really put it anywhere you want.
Old 17th August 2004, 11:45 PM   #4
so as long as its close to the speaker, its fine?
Old 18th August 2004, 01:38 PM   #5
DSZ71 is offline DSZ71  United States
Do a "Google" search for winisd. Its a program (freeware btw) that will help you design your box and calculates the port size and dimensions needed. Just type in your speakers parameters (ts) and desired Hz level....and wala!
MJK worksheets vs port location johngalt47 Multi-Way 3 9th March 2009 12:35 PM
Port Location ERICSPEEd Multi-Way 4 3rd December 2008 10:50 AM
Driver & Port Location gpsmithii Multi-Way 1 24th January 2006 05:26 PM
Port location andy2 Multi-Way 1 17th October 2005 10:20 PM
port location on linearrays justinc Multi-Way 16 26th April 2005 03:18 PM
Page generated in 0.10837 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1999-2013 diyAudio
