In Car Audio Setup HELP!!!
Old 25th June 2004, 06:31 PM   #1
zorb_rules is offline zorb_rules  Australia
Default In Car Audio Setup HELP!!!
Help me out her please Ive got:
2XMarathon 400 Watt 10inch subs
2X240 watt 3-way pioneer 6by9
and 2X180 watt 6inch pioneer cones
aswell as a 4X200 Watt audiopline amp
and a pioneer mp3 headunit.
Whats the best way to set all this up?
Old 25th June 2004, 06:38 PM   #2
maxw is offline maxw  United Kingdom
maxw's Avatar
need more info on your amp. Like is it 2 ohm stable when bridged to 2 channels? if it is, Id do this:
Bridge 2 channels of the amp giving you something like 1x 400W + 2x 200W. Then use the bridged 400W channel to power the two subs wired in parallel make a 2 ohm load. Then use the remaining 2x 200W channels to power either the front or the rear pair, this is upto you as it is a personal preference, most people would say the front ones. Then power the last pair of speakers from the HU. easy peasy aye
Old 25th June 2004, 06:41 PM   #3
Look ill be honest with ya I know jack botu car audio I can install but thats it I got given the amp for a bday present its and audioline al2004 its 4 channel bridgeable and tri mode has in built cross overs and stable into 2 ohms...not that I know wat it all means but thats what the box says
Old 25th June 2004, 06:57 PM   #4
maxw's Avatar
It should be fine in the config I said above then perhaps you should get some help you with the wiring or get some one else to install it. Although I probably wouldn't in your position
Old 25th June 2004, 07:05 PM   #5
why's that? whats wrong im so lost im not very electronically educated which is what leads to my next question....
a mate of mine wired up the amp and the subs and all the pseakers and he had them all running off the amp which from the sounds of it is very bad *lol* and now the amps gone dead...there was no burrning smell or anything and no blown protection fuse. The amp instructions says it has overload protection is this actually the 30A fuse I put in the front of it or another fuse inside..or what exactly?? Sorry Im so dumb I know...but im trying to learn
Old 26th June 2004, 08:19 AM   #6
maxw's Avatar
I dont know about that amp. There are a few threads on these forums along those lines, you should search and read them. We cant really help you with all the decisions on an install. You will definetly need to learn more. If you have any specific questions about Car audio then we can answer them but for situations like this you're basically on your own because its too hard and time consuming for some one to help you via the internet
Here's what you should do:
Always seach these forums before posting questions on here, it has most likely been asked before.
Car audio magazines provide ALOT of info and stuff to learn.
Seach the internet for car audio site and forums to learn too.
And use some puncuation! like the full stop
Good luck.
Old 28th June 2004, 10:57 AM   #7
I write like i talk sorry! its all one big sentAnce to me *lol* newayz thanks to all you guys for all of your help its much appreciated. Iv'e played around with installation with a mate of mine and its all looking good so thanks for all your advice and stuff Ill be sure to come back here in the future
In Car Audio Setup HELP!!!Hide this!Advertise here!
everyones audio setup? pat99 Car Audio 35 23rd January 2008 02:31 AM
I need some Identification help on this audio setup perzbenz Car Audio 5 13th October 2007 04:31 PM
car audio sub in an HT setup gompka Subwoofers 4 30th December 2005 03:07 AM
Audio Setup Help Tweak Car Audio 10 17th June 2004 07:07 PM
$1000 for car audio setup griff Everything Else 6 4th April 2002 08:50 AM
