Is it worth the effort?
Old 6th July 2004, 04:53 AM   #11
Hybrid fourdoor is offline Hybrid fourdoor  United States
Hybrid fourdoor's Avatar
As far as a center channel, you may consider guage pod mounts.
Mount like a 2" Tang Band in it. You wont get much bass, but it would be able to aim at the passengers, and dialog would be pretty intelligable.
I've actually thought about doing this using the A-pillar, having upper freq. coming from in front from full range units like above, and the using the doors for lower freq (like a 500Hz crossover). I think this would give much better high frequencies in a car....kinda like the Mach Ford sound system in the mustang, only these would actually be pointing at you. Again bass would severly be limited due to almost zero enclosure volume.
EDIT: Also if you have some fiberglassing experience, this could be surprisingly easy of a project (the initial center channel idea).
Is it worth the effort?Hide this!Advertise here!
Lowthers worth the effort? Shaun Full Range 4 3rd April 2008 04:49 PM
Yamaha CDC-615, Worth the effort? OzMikeH Digital Source 2 4th April 2007 01:49 AM
Would this be worth the effort? needtubes Pass Labs 4 22nd November 2005 06:22 PM
AT1100 arm worth the effort? tubenut Analogue Source 8 5th November 2005 10:42 PM
Is this mod worth the effort? clevegilbert Tubes / Valves 2 27th January 2004 01:23 PM
