UC2825 smps controller
UC 2825 PWM IC
Hi SSS,
Unitrode's (now TI's) numbering of chips goes something like this:
UC1XXX - Mil-Spec (-55C to +125C)
UC2XXX - Industrial (-40C to + 105C)
UC3XXX - Consumer (0C to +70C)
Hence, the UC 2825 is the industrial version of the UC3825. The Mil-Spec version would be the UC1825.
Basically, this series of PWM chips is pin-for-pin compatible with Motorola's (Now ON's) MC34025 (0C to +70C) and MC33025 (-40C to +105C) dual-ended PWM IC with 1MHZ oscillator. Good for off-line and DC-DC push-pull, half- and full-bridge topologies. Good bandwidth on the error amp, too. Can be used as either voltage-mode or current-mode.
Great chip! I have used them in 42-14V DC-DC Convcerters. A BIG :bigeyes: improvement over the SG1525/2525/3525 (400kHz max) voltage mode-only PWM ICs.
Hope this insight helps!
'73,
Steve, N8XO
