Go Back   Home > Forums > General Interest > Car Audio
Old 15th June 2004, 07:24 PM   #1
DFI is offline DFI  Romania
Default Need help on car SMPS
Can anyone plz help me by telling me if the attached schematic is going to work ? Thanks.
File Type: zip switch mode power supply for car amplifiers.zip (36.0 KB, 189 views)
Old 16th June 2004, 05:10 AM   #2
Tensop is offline Tensop  Lebanon
jesus.
Old 16th June 2004, 06:59 AM   #3
emre is offline emre  Turkey
Hi DFI,
It is not possible to tell if the SMPS is going to work or not by just checking the schematic, the PCB layout is quite critical too. So, I guess the only way to tell if this is going to work is to build the circuit and test it!
If you want to check the basic circuit (i.e. switching characteristics, loop stability) , I can recommend you to use Spice for circuit analysis( like LTspice, make a search on google).
Emre
Old 16th June 2004, 02:10 PM   #4
Thanks emre for the tip.
Old 16th June 2004, 06:43 PM   #5
One more question. Knowing that the MOSFETs are IRF 1405, how much power can I achieve from this power supply ??
Old 17th June 2004, 12:29 PM   #6
the limits wont be in the mosfets. more likely the toroidal transformer and/or (if used) output inductors
Old 17th June 2004, 02:07 PM   #7
sss is offline sss  Israel
sss's Avatar
Send a message via ICQ to sss
DFI :
man u are crazy
u are using 10 pairs of irf1405 ??? those are rated at 169A each
3 pairs will be enough for 500W smps
u cant just add million paralelled transistors to get more power , u gotta use 2 or more transformers if u really want to make a 2000KW + amp , is this what u are trying to do ???
plus :
i didnt check all the schematic but u allready got a serious problem !!
this is not the right way to connect the base transistors to the power mosfets !!!
R10 to R18 should be connected to the emmiters of Q9 and Q10 and not to each other !!
and Q9, Q10 , Q31 , Q32 should have emmiter resistors .
i guess there are more things wrong with this schematic , u better look at other circuits to see how its done
cheers
Old 17th June 2004, 02:50 PM   #8
Banned
Send a message via MSN to SkinnyBoy
parts will cost more than buying an amp premade....
Old 17th June 2004, 03:15 PM   #9
sss's Avatar
if u are doing it the wrong way.......
Old 17th June 2004, 03:18 PM   #10
thanks sss for the reply. can you draw a little schematic on how to connect those resistors pls so I can understand better? I would appreciate your help.
Tensop, I am planning on using two toroids R 80/40/15 which you can find at http://www.kaschke.de/english/frames...ringkerne.html
SkinnyBo, that is not the problem. Maybe where you live the assembled amplifiers are much cheaper, but here in Romania they are very expensive. For example, a 300W RMS amp is no less than $200, and the parts here cost me about $300 and I get to have a much more powerful amp than I can buy with those money.
Smps a2005r2003 Power Supplies 19 11th August 2011 07:19 AM
SMPS for B+ from PC PS jkeny Tubes / Valves 1 10th February 2007 08:52 PM
Smps Juani_12-5 Car Audio 8 20th January 2007 10:15 AM
Smps rinox Power Supplies 0 2nd September 2005 11:05 PM
SMPS for Hi-Fi? mr_push_pull Power Supplies 4 12th November 2004 04:45 PM
Page generated in 0.09323 seconds (81.83% PHP - 18.17% MySQL) with 11 queries
