diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Car Audio (http://www.diyaudio.com/forums/car-audio/)
-   -   Power supply for a active summing block. (http://www.diyaudio.com/forums/car-audio/35757-power-supply-active-summing-block.html)
S.C 10th June 2004 05:36 AM
2 Attachment(s)
I had been posting about a problem with my car amp and sub in Loudspeakers forum "My almost finished sub" , and the thread went to deep into amplifier so I start a new thread here to ask u guys about the non speakers stuff.
Ok, the following picture is the summing block I am going to build. However, how do I build a power supply for it to use in a car, and how do I determine what gain I want? I used some info form my CHy Moy headphone amp knowledge to draw this, so I am not sure will this work for car audio. Plz give me some advices.
tsmith1315 10th June 2004 07:18 AM
2 Attachment(s)
S.C asked:
You can build a surprisingly simple and effective power supply for powering op amps in a car... I hate to even post this... But it really does work.
All you have to do is make a voltage divider with two equal resistors, filter them with capacitors, and use the node where they join as your reference voltage.
(See the attached scan)
Choose identical resistor values that draw significantly more current than the IC's you are using, so the referance voltage will be stable. I usually used 100 ohms, but values as high as 1k could be reasonable for a low current IC. 100 ohms will be sufficient to easily run a couple of quad amps. Be sure the power rating for the resistor is adequate for the current it will draw.
A more precise supply can be made using op amps to derive the reference, but they will have to handle the supply current through their outputs. Besides, there's really no need to complicate things for this type of job.
This supply will leave a DC component in the output signal, simply use a decoupling capacitor in series with the output of the last IC to eliminate that.
You can use a transistor or relay in front of the divider to switch the supply on/off with the remote lead.
As far as the summing circuit goes, I've always been more comfortable summing into the inverted input because of it's virtual ground characteristic. Without the benefit of test equipment to verify performance, I feel this is the best way to ensure other impedances are influencing the circuit as little as possible.
I have been known to be wrong.
If you choose to use the inverted method, simply use an inverting follower for your output buffer. You can use that for your gain stage as well, if you want gain. I would suggest minimal gain ( no more than 2 or so) because you don't want to approach the 6 volt rails you created with the supply above.
By the way, nice job with the Dremel tool. Is that MDF you cut with that thing? You really should invest in a cheap jigsaw to save yourself some effort!
Tim
S.C 10th June 2004 08:06 AM
So is the refrence voltage will go to ground, and what is the point of puting a decouple cap in front of the resistors like (c) http://headwize.powerpill.org/images/eq12.gif from headwize
So I need to put one more decoupleing cap on the output while I already had one on the input.
I don't uinderstand the pt of this. Is the summing block will on all the time even my key wasn't there? I don't understand how to wire the battery to this summing block and amp too. Do I take a lead out of the stock head unit harness to get the voltage, or some other ways?
What do you mean by a follower? Is my IC B a follower, and will it work as the circuit I draw? Or I need some adjustment on it?
Tim
I hope I have spare money on tools too, drill press, saw, and router. If time and money is premited, I am willing to learn how to use mill, but the fact is I am only a spoiled college student who had never work before.
Immo_G 10th June 2004 12:39 PM
The headunits RCA ground is grounded (maybe via a 1k resistor, maybe not) to the car body, would this interfere with your circuit?
tsmith1315 10th June 2004 04:28 PM
from Immo_G:
Absolutely. That's why you have to use a decoupling cap on the output. Something in the 1 to 10uF range, electrolytic, and observe proper polarity. This will act as a subsonic filter of course, and limit slew rate as AC coupling does. Nothing is free!
If you know the input impedance of your amp, use it for R in the formula:
f=1/(2piRC)
to determine the subsonic filter frequency. If the one output is driving two inputs of the amp, that would be:
f=1/(piRC)
S.C wrote:
The idea of the circuit is to give you a reference other than ground. Ground becomes your (-) supply rail, V/2 (or about 6 volts) becomes your reference, and +12v becomes your (+) supply rail.
The reference (shown as ground in those drawings) is NOT grounded (not in car audio). The drawings are a little misleading. In the case of (a) or (b), it wouldn't matter. But in (c) it would short circuit the negative supply rail. The only thing connected to the reference are the connections to ground on the schematic you're using for the summing block.
Just connect the shield for the output RCA's to the input RCA's shield.
Notice on the drawing (c) isn't using batteries for a DC supply, it's using rectified AC. Therefore the capacitor on the input.
I don't see the one on the input as critical. One on the output is in this case, unless there is one internally in your amp.
Well, you can run this circuit from the accessory lead (on/off with the key) but it would be best to turn it on and off along with the amp. I don't remember, are you using the stock head unit? I'll post a drawing (later tonight or tomorrow) on how to incorporate the turn-on circuit into the power supply, and include battery and amp in the diagram. It would help to know which head unit you are using and if stock, what type of car.
A follower is actually called a "voltage follower", and simply follows the input signal. At first glance, it may seem pointless. They're very useful to isolate your circuits from the effects of external impedances. Therefore the name "buffer." Line drivers are buffers designed usually to drive long cables. An inverting follower mirrors the input signal to provide an output 180 out of phase with the input.
I'll have to look back at the schematic to be sure it's strictly a buffer...
Tim
sss 10th June 2004 06:36 PM
2 Attachment(s)
hello guys
dont u think the next config willgive u better resolts ?
Hybrid fourdoor 10th June 2004 11:26 PM
These are really handy for quick wood work
Handheld scroll saw at loewes. They can be had for $20-$40, and are pretty handy...takes a steady hand though ;)
S.C 11th June 2004 06:16 PM
Sorry for skipped on day of post. I recieved my amp yesterday, and I took my time on gaming after my 3rd chemistry test. So I'm back again, and I need to do a little shopping for installing the amp and try the bridge mode first. Also, I am not really sure how the sub out will act like, if it comes out to be the same signals from left and right then everything will be fine. Then I just need to connect it to the amp and drive sub seperatly. However, if this is really true, I can also change this block to a true buffer or blanced line output device. So the posts here are still useful for this application, and keep posting. Then I will test the sub outs later when I am installing my amp.
Originally posted by tsmith1315
from Immo_G:
f=1/(2piRC)
f=1/(piRC)
Are you talking about my design too?
So C1 will not do the job. CAn I take it out, and only run one cap on the end of IC B
Ok here is the spec of my car and the whole system:
Car: 96 Red Honda Civic Coupe
HU: Kenwood KDC-MPV5205 MP3/CD reciever:
- Preout Level/load (During Disc Play):
2000 mV /10 kOhm
- Preout impedance:
< 600 Ohm
Amp: Blaupunkt PA2150 Class T Amplifier
"Birth Certificate"
1.RMS output power : bridged (4Ohm) @ 1.0% THD
= Min power in any channel 480 Wrms.
2.RMS output power : non-bridged (2Ohm) @ 1.0% THD
= Min power in any channel 180 Wrms.
3.@ Rated power, bridged mode - 51 Amps
4.@ Rated power, non-bridged mode - 32 Amps
5.@ 33% rated power, non-bridged mode - 11 Amps
6.@ 10% rated power, non-bridged mode - 5 Amps
7.@ idle - 1.5 Amps
8.@ Rated power, non-bridged
A weighted
Average Value for all channels >100db
Test conditions: Loads 4Ohm resistive in all modes unless noted, voltage=13.8 Volts DC.
Input impendance - 10k ohms
Input signal voltage control range - 0.3-6.0 vrms
Trigger line current draw - @20mA
Subwoofer driver: JBL LC-S1200W
specifications
Recommended Amplifier Power Range: 12-200W
Sensitivity: 91dB
Frequency Response: 40HzV500Hz
Mounting Depth: 5" (127mm)
Cut-out Diameter: 10-3/4" (273mm)
Thiele and Small Parameters
Nominal Impedance: 4 Ohms
Revc: 3.45 Ohms
Fs: 27.4Hz
Vas: 124 Liters
Qms: 3.18
Qes: 0.37
Qts: 0.33
Mms: 109.2g
Levc: 2.2mH
Sealed-Enclosure Specifications
Enclosure Volume 1.25 cu. ft. (35.88 Liters)
Vented-Enclosure Specifications
Enclosure Volume 1.75 cu. ft. (49.54 Liters)
Port Diameter 4" (101.6mm)
Port Length 10-3/4" (273mm)
Bandpass-Enclosure Specifications
Sealed-Chamber Volume 1.25 cu. ft. (35.88 Liters)
Vented-Chamber Volume 1 cu. ft. (28.31 Liters)
Port Length 6" (152.4mm)
I think this will be more than enough details for you to answer my following questions regarding to your post. I had been reading different car audio site lately, and I found one extermely useful. So I understand I can get power supply form the circaret(spelling) lighter, or seting up a distrobution block from batt + voltage for this purpose. What is the differences and advantage on these ways? For the gain calculation, I think I will set the final summing block output voltage not more than 5. Since My amp max is 6 vrms, I think <5v will be save and the sound will be pretty decent. Am I right? And how can I calculate the final voltage which coming out from the active summing block with a voltage follower? I will redraw the sch, so this question can leave it by now.
So is it not a good idea to turn on everything at the same time with the remote power from the reciever?
Is it because the pop it created by the rush of the voltage flow?
I want to test the bridged mode and drive the sub in series to see how its work, and the package came with a high line level adapter, should I use it? Do you guys use normal RCA 2 males-2 males too? Or should I leave it for the summing block since its lead the female leads are wires only (easy assemble for PCB).
I think the IC B have few mistake, and I am going for NI confriguation. And what is the different between http://www.diyaudio.com/forums/attac...&postid=412639 section and this http://www.mhennessy.f9.co.uk/preamp/mix_amp.gif? I notice the different input method, but what is the different, and adventage?
Originally posted by sss
hello guys
What is that triangle thing? diodes?
I will think about it, but I really want a drill press first.
sss 11th June 2004 09:22 PM
those are zener diodes , u can use 4.7V or 5.1V zener diodes
instead of the resistor network and get a much better power supply
:D
officeboy 11th June 2004 09:35 PM
I'm kinda jumping in, in the middle here, but why does this need to be active? :confused:
L/R summing is as simple as 2 resistors. Of course adding phase switches is a whole different matter, but won't your sub amp have phase and if not, why don't you just swap the polarity of the speaker?
What you are doing is very simple.
The way you are doing it is not. :whazzat:
Copyright 1999-2017 diyAudio
